Tool Talk Discussion Forum
Webster Compressor
Garnet
11-11-2006 19:49:10
Hello everyone, glad I found this web site. I purchased a Webster M#721 1 S#30072J5 a few years ago with a shot 7 1/2 HP 3ph motor. Installed a new 7.5 HP single phase motor, set the rotation so the pumps wheel blows air over the heads. The compressor seems slow to build up pressure and it kicked out the oil plug I made. Didn't come with one above the oil level glass. There was a noticeable knocking noise while running, though it didn�t appear too bad.
I would love to get a hold of a manual or at least a copy. All the talk of reeds and stuff makes no sense to me. Must be compressor specific. I believe that the rings are shot with all the blow by. But I don�t want to start taking it apart without some idea of what I should be looking for and what I should replace while it�s open.
I appreciate your replies and help.
Garnet
11-11-2006 23:00:35
 Re: Webster Compressor in reply to Garnet, 11-11-2006 19:49:10
Thanks to everyone, I really appreciate all the replies. But I have to say XRogerX you boggle my mind with your in depth knowledge of Webster compressors. Are you sure you�re not the grandson of the original manufacturer?
I really appreciate your time and knowledge and hope that someday I or at least someone else, is able to assist you as you have assisted all of us. I am sure I speak for all of us that you have helped, when I say thank you.
Sincerely Garnet
XRogerX
11-11-2006 22:05:52
With 5 valve heads, this is a Model 72, as shown in the first two digits of the model number. There should be a crankcase breather on top of the back end of the crankcase. It is simply a flat metal disc that reciprocates up and down that acts as a pcv valve. If this is removed and the hole is plugged, you can bet your bottom dollar that you will have serious crankcase pressure buildup. It is usually mounted in the end of a 1/4" street elbow coming out of the end cover. The main oil fill is the 1" plug directly above, and to the right of the sightglass. The breather should be straight up from the sightglass, at the top of the end cover. I am surprised the sight glass didn't blow out of the crankcase. Knocking in a Webster is usually one of three things 1) The valves are loose in the head 2) The small ends are worn oval in the rods 3) The centrifugal unloader weights have worn to a point where they are loose and slap during operation. Problem 1 is easiest to solve, it simply require renewal of the head gasket with some heavy, high quality replacement material. We used to use wire-reinforced gasket for this. If the valves are left loose for a long period of time, they can move about and wear out the cast iron support points inside the head and it will be useless. Problem 2 is quite common unfortunately. Either the rods or the piston or the wristpin or all three have developed some slack, or a LOT of slack, and it is knocking badly. Webster HP pistons suffer from this more than most, especially if oil changes are neglected (which is most of the time). The MDF in the heads makes it sound like maintenance wasn't a priority where it was located, so don't be shocked if you find the small ends giving trouble. There may be a way around this. If the rods are bronze, you can simply bore the small ends and push in new oilite bushings, which are readily available from most any bearing shop. Wristpins can be turned out of good quality steel like 4130. Get the surface finish as smooth as you can, since some Websters use pinned wristpins and the bearing surface is in the piston itself. If the piston is worn, it is a little more difficult to fix, since they are hard to chuck up in a lathe to turn out the wristpin bores. It can be done, and then bushed, once again with an oilite bushing. the result is probably superior to the original design after that. If the rods are aluminum, they may be able to be rebushed, but there tends to be less "meat' on them than the old bronze rods, so it's difficult. Some of the last rods had needle bearing small ends and bearing shells, which were the best of all. If there is slack in the big ends (plain rods with no bearing shells), you can shave a few thou off the rod end caps to tighten up the clearances a bit. Make sure the oil dipper pins are re-attached if they are removed. These provide the splash lubrication to the compressor, and it will die a fast, painful death without them. Problem three can be discerned by pulling off the end cover on the opposite end of the crankcase from the flywheel. There are two spring loaded weights that open and close the unloader valve. The fingers on the end of these weights wear after awhile, allowing the weights to slap around a bit. If it is bad enough, the weights can actually contact the inside of the case. The split-pins that hold the weights in place can also develop slack and cause the same problem. The cast iron used in Websters seems to be prone to wear when the unit is neglected. Websters have been out of production since the late 80's. The remains of the company was purchased by a former employees who continued to sell parts, and have some remanufactured. He passed away, and one of his children took over, who has also since passed away. The company which deals in Webster parts now is Compresseurs Quebec. You might still be in luck if you need new parts, although major items like cranks are a special order and cost $$$. I believe blocks are still relatively inexpensive however. Normal wear items like rings and valves should be no problem. It is also entirely possible that your compressor is a-ok, since these machines did have a deep, distinctive "thump" on the intake. I "MIGHT" be able to score a manual for you and scan it in, but I can't promise anything. Good luck. Weigh the cost of repairs against the age of the machine before spending any money. All this advice assumes you could do the work yourself, since sending it out would be prohibitively expensive.
Garnet
11-13-2006 08:46:48
 Re: Webster Compressor in reply to XRogerX, 11-11-2006 22:05:52
Another update on my compressor. I cleaned the valves as you suggested and I have to say that there is next to no wear on these either. I am beginning to think I lucked out on my unit.
I'm thinking that the compressor was rebuilt just prior to the cabinet shop purchasing it. They must of ran it until it become so dirty the valves stopped working and the 3 phase motor burned out. With the expense of 7HP motors and a compressor from a defunct company that was very slow making up air. They probably just replaced it with a Princess Auto Special. It�s the only explanation I can think of, that fits the pristine condition of the internal parts matched with the horrific maintenance habits of the cabinet shop.
Anyways I have contacted that Quebec Company for an exploded view so that I can order gaskets. I went to Princess Auto on Sunday to look at their big compressors; I wanted to get a handle on that crankcase breather hole. Their units are plumbed back into the LP side of the heads. I was wondering if I could make a thick expansion plate between the compressor head and the air filter adaptor. Drill hole from the bottom and tap it so I can run a copper line up from the crankcase. This would recycle the air back and keep dust out. (My primary concern)
I have contacted that Quebec Company regarding a manual and/or exploded view of the parts. If they have nothing XRogerX you mentioned you may be able to get a hold of a copy of the manual for my model 72. If so let me know how much your copy/printing costs, shipping, etc. is and I will send you the money in advance to cover any of your expenses.
Charles (in GA)
11-12-2006 09:07:49
My apologies Roger, I added a **d** in your name (in my other post) that doesn't belong.
Charles
135 Fan
11-12-2006 01:14:02
Roger, since you are the expert on Webster. On my 55 which I was told is one of the best compressors made, it is not putting out much air. Could I just need to lap the valves as well? It doesn't make any odd noises but I loaned it to my neighbor to sandblast his steel fence posts and I don't think he ever let it cool off a bit. Of course he never mentioned anything was wrong until I was using it. Any help would be appreciated. Thanks Dave
XRogerX
11-12-2006 10:00:25
 Re: Webster Compressor in reply to 135 Fan, 11-12-2006 01:14:02
You can try lapping the valves, it certainly can't hurt. If you are in a bind, I believe you can put valves from a Sanborn SC23 in that compressor. I know we swapped out SC23 valves with Webster valves more than once, since the Webster valves were superior. If you can't get the original parts anymore, you could try going to Air Electric in Edmonton, since they were the Sanborn dealers when I lived there. Princess Auto sells these Sanborn pumps (the 10hp v4 and 5hp twin) but they are notorious for not stocking parts for their stuff. You can try a small compressor shop to get new valve plates and overhaul parts. You could try Phillray Eqipment at 2920 Parson's Road, he may be able to get parts for you. There was also a company called Rocky Mountain Air, which you could try as well. Generally, the bigger shops don't want to deal with small stuff like this, so you might have to look around a bit. If the compressor is not pumping oil, don't bother with the rings. Inquire about a "head overhaul kit" which would give you everything you need to redo the top end if necessary.
135 Fan
11-12-2006 10:11:49
 Re: Webster Compressor in reply to XRogerX, 11-12-2006 10:00:25
Thanks Roger. It's good you used to live here. My compressor isn't pumping oil, so I'll look into a head overhaul kit. Days painting supplies used to be the Webster dealer. That's who told me former employees were making them. That was a while ago though. Thanks again. Dave
135 Fan
11-11-2006 21:55:21
Webster was a good compressor. A former dealer of them told me that after they stopped making them, some of the old employees were making them as well as spare parts. That was several years ago but Websters were pretty common at one time. I have a model 55 all cast iron that puts out 20 CFM but I need to do rings and/or valves in it. It has an 8 hp Honda engine and weighs a ton. Dave
Charles (in GA)
11-11-2006 21:04:49
Rodger is the compressor expert on here, hopefully he will see this thread.
Charles
Bob
11-11-2006 19:56:54
Sometimes, the reed valves get dirt in them, and disassembly and cleaning is all that is needed.
Or, a reed or spring may be broken.
Compressors generally have a VENTED crankcase fill plug, or some other crankcase vent.
If your's has no other vent, and you put in a solid plug, that explains it popping out.
Garnet
11-11-2006 19:55:25
Webster Update:
I decided to putter with the compressor tonight. I removed the air cleaner and put my finger inside to see what was there. MDF saw dust! I had purchased the compressor from a cabinet shop that was closing down. I figured there would be some contamination since the air filter was not fitting properly. Which I had fixed the first day I got the unit. I was not prepared for not being able to feel any steel!
That clinched it, off with the head. (#G163) Here�s what I found. Two pistons (no surprise) the first one in line is 4 �� in diameter, the last piston is 2 �� in diameter; both with a 3 �� stroke. The pistons look and feel tight (though really dirty) no noticeable play when I tried to wiggle them. Washed both up with a varsol solvent. The piston walls have the crisscross of honing still on them. No signs of scoring.
Opened the crank case for an inspection. Cast crank (#G110) and new looking connecting rods with no noticeable play at all. The two end bearings have no sign of play either. Kind of a weird oil pickup system, there is a wire extending from each connecting rod. Oh well as pointed out in these forums, it�s a Webster.
The head has five �pucks� that control the air. Depending on which way they are installed controls the intake and exhaust. Each unit is about 2 5/16� across and 1� deep. There are two for the first intake, a third exhaust with one intake and one exhaust on the smaller piston. The first two intakes are covered with MDF saw dust.
Question 1) Can these �pucks� be soaked in a varsol bath?
Question 2) Would this have caused the slow pressure build up and excessive crank air pressure?
Question 3) When I do reassemble this unit does anyone know what the head bolt torque is?
Ounce again I would like to thank you in advance for your time taken in responding to my questions.
XRogerX
11-11-2006 22:17:48
 Re: Webster Compressor in reply to Garnet, 11-11-2006 19:55:25
It would be best to disassmble the valves (one at a time) and remove the spring and valve plate. If the plate is flat (no groove worn in it) it can usually be lapped clean on a good flat surface with a sticky autobody sanding disc stuck to it. apply some Varsol (mineral spirits) and lap clean. The same can be done to clean up the valve seats. Just lap them in a figure 8 pattern until you have a nice, shiny ring on the outside and inside edge of the valve seat. Reassemble the valve. Hold the valve so that the three hole are facing up and fill it with Varsol. The Varsol should hold, with no drips. If it runs out, or drips out, further lapping is necessary. If it takes more than, say, 30 seconds for it to drip out, the valve is plenty flat, and sealing well enough. If the valve disc is worn, lapping may not be enough, and new discs are in order. Springs can sometimes become razor sharp after a lot of use as well, so don't be surprised if you need new ones. Check to see if they have gouged the inner circumference of the valve spring guide. I can guarantee that the intake valves on the LP cylinder are fouled with MDF, and not operating properly. You might have been running on just the HP cylinder. You can tell this with a pressure reading on the intercooler. If it is reading very low, or zero psi, the LP cylinder is doing nothing.
