Tool Talk Discussion Forum
Lathe chuck jaws
Joe in Tennesse
11-11-2006 17:33:12
I have an old craftsman lathe that Sears no longer stocks parts for. I have lost one of the inside chuck jaws. The chuck is a 3jaw 5" diameter and is scrolled manually with a T handle. I cant find any manufacturer name on the chuck.
Is there anywhere I might find a replacement set of inside jaws?
Thanks
MikeCatthemuseum
11-12-2006 16:00:39
 Re: Lathe chuck jaws in reply to Joe in Tennessee, 11-11-2006 17:33:12
Get a new or good condition used chuck with both sets of jaws. As has been said, you'll have to buy a set and good luck getting the to match the pitch of your scroll, much less getting the timing right. Probably cheaper to get another chuck rather than buy new jaws anyway.
Gerald J.
11-11-2006 20:09:46
You'll wish a set, not just the one jaw, and then you may have to grind them to get the work close to center. A three jaw chuck has the properties of almost centering, but rarely does it precisely. Changing the jaws won't help that centering. Particular machinists use a dial indicator and a 4 jaw independent jaw chuck and can make the work run perfectly true, not with a few thousandths wobble.
Gerald J.
Glen in TX
11-11-2006 20:00:11
Clausing Industrial
Jim K
11-11-2006 19:27:38
Do a search on Grizzly supply, They sell lathes and machine shop/wood production shop stuff. P.S. seems strange seeing this post after using my "1940's style CRAFTSMAN lathe yesterday to make a crankshaft pully spacer on a 347 mustang engine that I'm building with my son. Been almost exactly a year sinced I used it.
Has the Babitt bearings but still works nice. They had a three jaw chuck for my "1950's" Walker Turner lathe.(woodturning) I also have a early "1900's" F.E. Reed 50" converted X-lineshaft driven(woodturning)made right here in Worcester Ma.
Bob
11-11-2006 19:02:50
There's always Sears/Atlas lathe parts on ebay. Shouldn't have to watch for too long to find a chuck.
Atlas is now Clausing. They MAY have parts, it won't hurt to check... it's a free call.
Clausing Industrial, Inc.
1819 N. Pitcher Street
Kalamazoo, MI 49007-1886
Phone: 800-323-0972 FAX: 269-345-5945
Service Center Goshen Indiana
811 Eisenhower Drive South
Goshen, IN 46526
Phone: 800-535-6553 FAX: 574-533-0403
Or, get a new chuck from Enco. You may be able to order it with a ready-machined mounting plate, or you may have to get a blank one, and thread it yourself.
Bob
11-11-2006 19:27:32
 Re: Lathe chuck jaws in reply to Bob, 11-11-2006 19:02:50
Also, here's a link to the Practical Machinist Forum:
Hobo,NC
11-11-2006 18:21:47
Mine izz so old I think it made the parts fer the mayflower. Enny ways I had to have a machine shop git me a 3 jaw chuck and he made the part that screws to the lay arbor to adapt to the new chuck. I spec he got a small 3 jaw chuck new and adapted it. You do not won�t to know the cost. Hopefully yours izz a later model and the chuck kin be had. Mine izz also a craftsman but it wuz made by atlas. The arbor in mine runs in bush�ins not bearings like the later ones did. I have the original manual fer it and the atlas manual for the later type.
Foxquads
11-11-2006 17:43:39
Try looking for South Bend or Atlas. I think one or both made lathes for Sears then...If it's a three jaw , you will need the correct numbered jaw, or you will have to have it "ground in"...
