Tool Talk Discussion Forum
TIn Roof Needs Sum TLC
Hobo,NC
11-10-2006 16:55:12
I have a shed with a tin roof, the tin izz starting to rust from the lower ends to �bout a foot up. Theirs not much pitch to it. I either need to paint it or apply sum cool seal.
I have a nutter shed that�s a car port. The tin on it izz star�in to git in bad shape. Unlike the first shed you kin see the roof so I would like it to look good. One of my old buildings had a tin roof and I would coat it every few years with cool seal. I did not think it held up good so that�s the reason I am think�in �bout using paint now. I would want sumin that would last 5 years or more.
What�s a recommendation, Thanks
paul
11-10-2006 20:29:06
 Re: TIn Roof Needs Sum TLC in reply to Hobo,NC, 11-10-2006 16:55:12
I have always been happy with the aluminumn/oil paint stuff the migrant painters apply, seems to last me 10 years or more between paintings, I try to catch it be4 the rust is too bad & it keeps things fresh & good & very shiny.
--->Paul
XRogerX
11-10-2006 20:23:20
I used this stuff to redo the roof on the house this summer. It goes on like paint, then cures to a rubber. This is on a "V" shaped roof, with the low part in the middle (yes, it's a BAD design for a rainy, snowy city). It was $125 CAN for 5 gallons, 100sq/ft coverage to a gallon. The only bad part is the need for it to be dry long enough for it to cure, and to be warm enough for it to cure (minimum 45 deg F for application). It washes up like latex. We have had no leaks now for months. We did an entire 1500 sq ft roof for less than $2000, so a car port would be quite cheap. I rolled it on, due to the proximity of the neighbour's homes and the desire no to end up in a messy lawsuit due to overspray, but a high pressure airless spayer is the way to go.
135 Fan
11-10-2006 17:13:27
Why not use the black tar like roof repair? That's what they use to fix mobile home roofs. Dave
