Engine paint
Andrew
03-31-2001 06:39:39
I have a engine that I need to paint a spring green color, where could I find this color? can I use regular paint or heat resistent paint? It is a air cooled briggs engine.Thanks
Andrew
Rod MI
03-31-2001 12:26:51
 Re: engine paint in reply to Andrew, 03-31-2001 06:39:39
I have used regular paint from hard ware store but now I remove the paint for better cooling for Go-Kart racing
Andrew
03-31-2001 16:00:43
 Re: Re: engine paint in reply to Rod MI, 03-31-2001 12:26:51
So you can use just use any old paint at the hardware store or a specific kind? Thanks
Rod Mi
03-31-2001 17:35:54
 Re: Re: Re: engine paint in reply to Andrew, 03-31-2001 16:00:43
Any that is made for steel or aluminum should work I should say it will probable start to peal after a will (Block) even factory brigges paint dues good luck and don�t put to much paint on engine or it will hole the heat in the engine just enufe to cover the aluminum and no primer
