Forget the MIG in this application. Not trying to beat the Oxy-acetylyne drum again, but electric welding and cast iron just don't mix well. (Yes, there are electric methods that can work, but it's still pretty iffy by comparison for the average joe). The heat is too intense and too concentrated to work well. If you just have to weld this, pre-heat to a dull red, weld it with a BIG torch and a cast iron rod and keep the whole works hot as you work. Run a pretty long acetylene feather to keep the carbon content up. Stick it in a heat treat oven at about 1900degrees and let it cool off over a whole day. You will have a good, workable cast iron weld, anything else is going to have hard spots. If you do not have access to the heating equpiment and the skill with a torch, you are not going to get far this way. You need to understand what is happening. The problem is that cast iron, if allowed to cool fairly quickly, is hard and brittle as glass. It's called WHITE iron. Most of the old lathe builders cast their beds against iron chills in the mold to harden the wearing surfaces for this reason. Unless you can weld with that whole part at near the melting temp, and then cool it as slowly as it would have in a green sand mold in the foundry, you are going to have a hard weld and problems not only with machining, but also cracking on down the road. If iron is to be repaired in the usual shop, the best technique is the steel reinforced brazing method Dave mentions. I have used steel keys and inserts to repair all kinds of broken cast iron machinery; tapping and bolting the parts together with the keys well enough to effect a repair and then brazing the keys, bolts and all together. I'll guarantee one of my fixes 100%, something most professional welding shops won't even do. Where you can, just helicoil them and skip the welding. If you have to plug up a hole and intend to tap it, braze in a piece of steel adn try to keep the whole works real nice and hot and cool slowly. You can bury in sand for insurance, but I have had excellent results just air cooling in a calm, non-drafty shop using the steel reinforcment. Beware nickel arc rods. They are the primary source of my misery. In the hands of an expert they might work OK, but I have never seen a good nickel repair so far. Guys hit the part with a weed burner adn then stick it together with nickel. They can probably hear it cracking as it cools. I have repaired many a sorry nickel rod weld that cracked at the base metal. The worst part is that you have to grind all that nickel out if you want a cast iron weld or brazing job to stick. Brass runs off nickel like water off oil, no matter how much flux you use.
