Tool Talk Discussion Forum
WainRoy backhoe any good?
Quebec Bob
11-07-2006 10:09:08
I am looking at a Wain Roy 3 pt. backhoe at a dealer. Can anyone give me their experience with them? They were made in Massachusetts and are now owned by Woods. This is an older model, appears from the picture to be in good shape with few welds. I notice that it is made with hydraulics to move each action, including the swing. Any tips? Things to look out for? Thanks.
Jim K
11-09-2006 18:53:45
 Re: WainRoy backhoe any good? in reply to Quebec Bob, 11-07-2006 10:09:08
i HAVE ONE THAT IS MOUNTED TO A 1961 fORDSON power major. it's well worn has a few welding repairs, but it can still lift a 400 lb rock with no problem. It's an old beast and I love it.
P.S. can also remove it from the tractor in about ten minutes byt loosening two 3/4" nuts and two hydraulic quick couplings.
`Bernie in MA
11-07-2006 16:08:15
Roy was the inventor of the modern hydraulic backhoe. I know his daughter, used to work with one of his sons.
135 Fan
11-07-2006 12:17:30
All backhoes use hydraulics for all functions. Some swing mechanisms are different but still hydraulic. Check if the pins and bushings are tight. It's a good indication if it was greased regularly. Is there slop in any of the movements? Can you try it out? look for leaks or a valve not operating properly. Wain-Roy is a good name. They made clam buckets for hoes. Woods is also good quality. Dave
