Tool Talk Discussion Forum
Where to get thin gasket mat'l
njs
11-07-2006 06:25:40
Not having success finding .005/6" or .010"
gasket material--unless I want 150 feetof it.
Any suggestions?
Thanks
wdTom
11-07-2006 18:21:57
 Re: Where to get thin gasket mat'l in reply to njs, 11-07-2006 06:25:40
Use paper, maybe spray a little gasket spray on it after it is cut out.
Ol CHIEF
11-07-2006 17:35:27
Contact Chesterton Packing Co they have Reps.all over.Also Mc Master Carr. On shipboard we used the plastic shim stock which comes and in all thicknesses and is color coded. It works very well if your matched surfaces are machined well.
Bud in NC
11-07-2006 17:31:48
OK - I've been "retarded" for a few years and was having a brain cramp - here's a link to one the companies I used to buy from - the other's must have changed name or gone Tango Uniform....
Link
Bud in NC
11-07-2006 15:29:22
Here's a starting place - we used to use .005" and such for setting the thrust and clearences on pumps. Veggie fiber is the only type I've seen that you get that thin - good luck!
http://phelpsweb.com/phel3_13.htm
Jiles
11-07-2006 06:47:18
I don't think you can buy any normal gasket material less then 1/64---.0155. The thinner gaskets, like used in some carburation applications come from a large sheet as you have mentioned. Depending on how big a piece you need you could do as I have done and sand the thickness down. Of course this is only practicle with a very small piece. I have bought "soft" shim stock, preferably copper and made gaskets. Most Industrial Supply houses carry this material. You might consider silicone or other liquid gasket material if the clearance will allow.
BigMarv1085
11-07-2006 08:29:00
 Re: Where to get thin gasket mat'l in reply to Jiles, 11-07-2006 06:47:18
I have seen them made out of construction paper, cereal boxes, etc.
daves 40 acre
11-09-2006 09:30:43
 Re: Where to get thin gasket mat'l in reply to BigMarv1085, 11-07-2006 08:29:00
I use cardboard from cereal boxes and such too, work great never had one leak have a whole bunch saved up in barn for making gaskets.
varmint
11-08-2006 08:32:20
yeh. with a little #2 permatex about anything will work
