Tool Talk Discussion Forum
Skidloader Hydraulics
vernon stanton
11-06-2006 10:42:16
I just purchased a 1975 Mustang 1200 skid steer and it says to use A type Automatic transmission fluid in the hydraulics. I have a early forty"s Hough payloader I use a genaric hydraulic fliud in. Anypne know if I can use it in the Mustang. I would rather keep them the same.
westportdean
11-28-2006 17:12:17
 Re: Skidloader Hydraulics in reply to vernon stanton, 11-06-2006 10:42:16
I have a new holland l445 skid steer.... and just had a chain replaced and a lift boom cyl resealed.... the new holland dealer put "whatever" hydrolic fluid in... and now it had a shreaking sound when operariting the bucket and boom... and they run really slow and have less power.... the manual say to use dextron.....
could the "whatever" hydro be the problem?
the dealer says the filter probably needs replacing, but it was repalced a few months ago ( 8 hr's op time )
watcha think?
also... the new fluid feels really thin on the dip stick.... more like water than oil.
but.... the drive hydrosatats seem to work ok...?
westportdean
12-17-2006 04:50:40
 Re: Skidloader Hydraulics in reply to westportdean, 11-28-2006 17:12:17
just wanted to update everyone and say that ... the screen was clogged.... now all's good.
135 Fan
11-28-2006 18:19:38
Most skid steers, not all, have seperate compartments for hyd. and chain case. Oil in chain case isn't a big deal. Hyd. is. I'd go back to the dealer and have all the hyd. fluid changed for the proper spec. fluid. Especially if it worked fine before. Hyd. repairs don't come cheap. Dave
vernon
11-07-2006 04:05:45
Thanks, Sounds like I had better stick with the trans fluid.
RJ-AZ
11-06-2006 18:08:59
Stick with the Dexron. We are running Dexron/Mercon in the one I repair and service. There is a spec for a non-flammable fluid that nobody can afford. The chain cases can run the regular hyd oil though.
old
11-06-2006 12:34:04
I have to agree with 135, they are differant and if it has had the tranny fluid in it you better stay with the tranny fluid because the 2 will not mix well
135 Fan
11-06-2006 10:50:25
I would stick with what the OEM says. They are different oils. Dave
