OA welding is just like playing a piano, it just takes preactice to get good at it. I started with an OA torch only, so I could not grab that stick welder and zap stuff together. I had no choice but to learn, and I wanted that knowledge. I had seen one of our volunteers at the museum (an IA) weld some tubing into a J-2 frame. The welds looked beautiful and the tubing was SOOOO thin. OA welding is technically the ONLY FAA approved field repair for an airframe. I sought to acquire that skill. I got some old damaged airplane parts, cut the tubing out and started welding bits together in various angles and joints. With some pointers from him and many, many bottles of gas under my belt, he now accepts my airframe welding as sufficient. That is something I am extremely proud of. In additon, it taught me more about welding and I can now WEAR OUT a stick welder. I can lay down welds with a 6013 that peel themselves using a crappy little Lincoln buzz box. I am also pretty capable on a TIG machine. I don't even bother with MIG thus far. I own one (little 110v machine), but have never struck an arc with it. One of the tricks, just as you say is running hot enough. The most common beginner mistake is running a big tip and not enough pressure. It takes a long while to get the metal up to temp and the torch cracks and pops. Once there, the rod keeps sticking, the bead looks afwul and welding is just no fun at all. As you say, get it hot FAST. If you can count more than ten before the work is up to welding temp, go up a tip size. If it's cracking and popping, drop a size and crank more gas to it to keep the velocity up. In aircraft work, and many other applications, OA has another advantage... that large spread of heat. Electric welding sometimes heats and cools so fast it creates a hard zone around the weld due to quenching. This results in cracking. If you TIG, MIG, or stick weld an airplane frame (and yes some were stick welded at the factory), the joints must be normalized with a rosebud torch. Makes very little sense to TIG weld it when you are going to come back and heat it cherry red with a torch anyway. This same thing can crop up in the weirdest places. Last year I bought a 72 Chevy 3/4 ton pickup converted to a flatbed. The left door wouldn't close very well. Upon inspection, the door had cracked around the upper hinge and somebody tried to stick weld it back. It looked awful and was cracking right at the joints. Ten minutes with my torch and a welding rod (no coat hanger on this one), and it has held for a year now with no further cracking even though I only tacked it in a few spots.
