Tool Talk Discussion Forum
Massey 50 - Generator Short?
Parabrush
11-03-2006 20:50:09
Hello All. I'm a young lad searching for old answers.
We're workin on a Massey 50 Gas 12 V system. We have noticed a "short" in the wiring. The battery drains down to dead overnight. I have traced all the wiring to spec and seems ok. Tractor runs good. Although if I take the wire off the F terminal on the generator the short is gone. I know this may sound silly, but is it more than likey the generator or should i also investigate elsewhere?
dan hill
11-04-2006 03:45:57
 Re: Massey 50 - Generator Short? in reply to Parabrush, 11-03-2006 20:50:09
check regulator for points staying closed when engine is stopped.Erodded points or low spring tension will stick points.Note that coil or flat springs pull points open when engine stops.
parabrush
11-07-2006 20:11:51
 Re: Massey 50 - Generator Short? in reply to dan hill, 11-04-2006 03:45:57
Thank you. The regulator is serviceable correct. Simply take apart and check the point inside. Should any lubricant be used inside the regulator? Thank you for the response.
