Tractor tire repair?
al
03-29-2001 19:15:04
I have a cut in the top of a rear tractor tire.
4 inches long throigh cords. Any Hope?
CDH
03-30-2001 16:00:08
 Re: Tractor tire repair? in reply to al, 03-29-2001 19:15:04
AL
seen a man patch a 5 to 6"cut in a 13.6x38 tire laced it up with plastic baler twine and put a boot in it about 4 years and it is still running it today food for thought CDH
Brian G. NY
03-30-2001 13:04:41
I've had good success with repairing large cuts in tractor tires using the so-called "boot" patches. I use a wire brush on an air die grinder to really get down to some "live" rubber. Try to pull the crack together as tight as possible before applying the patch. The last one I repaired, I filled the crack from the outside with black silicon gasket maker. This was done about 6 months ago and the silicon is holding real well. I think this will help the longevity of the patch by keeping out the dirt, water and whatever.
Jerry B
03-30-2001 06:12:31
The local tire shop does something they call a "section repair" on torn tires. It involves a vulcanizing process to melt a repair patch into the tire casing. Never saw it done but that is what they told me. Costs more but is better than a boot In my opinion.
Mike
03-30-2001 01:36:22
If the cut is from damage and not dry rot you may have a chance at repair. Put a boot twice the length of the injury over it. The key to success is using enough cleaner and letting it dry properly. You are only buying yourself some time, eventualy dirt will enter the original hole and push repair loose. I have seen them last 3-4 yrs. Good luck
