Tool Talk Discussion Forum
another vapor barrier question o/t
glennster
10-31-2006 14:21:17
im in the planing stagess for building a secret mens club house out in my woods. 12 ft x 24 ft. 8ft walls. the building will set on 8x8 treated posts from a pole barn, approximately 4 ft off the ground.(the creek has a habit of flooding so i am above the high water)i plan on using 2x12 treated floor joists. should i put a vapor barrier between the joists and the plywood floor deck. (treated plywood also) i was thinking on using something like tyvek stapled to the top side of the joists and then lay the plywood over it? or any other ideas?
Al m
10-31-2006 14:50:04
 Re: another vapor barrier question o/t in reply to glennster, 10-31-2006 14:21:17
Tyvek is not a vapor barrier as it breathes and should be applied to the outside or cold side of the wall.Vapor barrier should always be on the warm side of the insulation or it will cause condensation that can rot your joists.I think if it was me i would skip a vapour barrier on the floor as spilt liquids and mop water will not get past and rot the flooring material.Ridgid isulation works well on grade as it is more resiliant to moisture than bats. Sounds like a good sized boy's club,best of luck
Al
