Tool Talk Discussion Forum
V-pulley
`Bernie in MA
10-30-2006 18:08:07
Does anyone know if there is such a thing as a v-pulley that is made in two halves so that it can be clamped over a shaft? TIA
Dusty MI
10-31-2006 17:57:30
 Re: V-pulley in reply to `Bernie in MA, 10-30-2006 18:08:07
I think the one you are looking for is made by Browning, W.W. Grainger does handle them. They are a very good pulley. They work well where the origial pulley has worked loose and worned the shaft and now you can't keep it tight. This type of pulley squeezes the shaft, I have never seen one come loose.
Dusty
old art
10-31-2006 16:54:19
have seen them try W W.Granger or flud power (use to be berry bearing. i think )
Sid
10-30-2006 20:13:29
I do not know how what they came off of but I have seen pulleys like you described in junk I mean treasure piles.
vally farm
10-30-2006 18:57:47
Had one that was on a John Deere H. It clamped om the fan shaft up near the radiator. I'm not sure what it was for, but bolted on a Dodge power steering pump to give it live hyds. Never had any belt wear problem, but then again, it was 60 yrs old and they built things to fit/work/last back then. Mike
135 Fan
10-30-2006 18:12:39
I've never heard of a two piece pulley. I think it would be hard on a belt. I do know that they pulleys that have a bushing that goes on the shaft and is bolted to the pulley to suck it on tight. Browning as well as others make those. Hope this helps. Dave
135 Fan
10-30-2006 18:22:15
 Re: V-pulley in reply to 135 Fan, 10-30-2006 18:12:39
I was thinking of a two piece pulley that goes on like a two piece shaft collar. There is pulleys that the two sides that grab the belt are seperate, like a furnace pulley. I don't think a pulley would work very good if it had two seperate half round pieces. I'm getting confused now. Dave
old
10-30-2006 19:47:00
 Re: V-pulley in reply to 135 Fan, 10-30-2006 18:22:15
The old 2 piece pulleys work very well and I still have a sickle mower with one on it. As I said in my post below they made them that way to be able to adjust the speed of the pulley so you could increase or decrease speed on the equipment. For an example of where one is use is on my Allis C sickle mower. Works the same way as the water pupm pulleys on the farmall tractors where you make the pully wider to loosen the fan belt or narrower to tighten the belt. The one for my siclke mower has shims you add to the center or remove to make it wider so the blet will ride lower in the pulley. Believe me they work very well and do not wear out the belt any faster then one that doesn't adjust
old
10-30-2006 18:12:15
A lot of companys used them on things like sickle mowers etc. The way they works was with a spacer in them so the more spacers you put in the closer the belt would run to the center. That way it was easy to speed up or slow down the equipment. Allis is one of the companys I know used them
