Hi Bob, I have 2 wire feed welders, 1 is a relatively cheap one, & the other a century. Both run on 120v. They have up to .030" wire capability & a claimed welding capacity up to 3/16". I have had great experience with both! I have welded up to 1/2" with both, this takes a couple passes, but will with most wire feeds. There are a couple things that the smaller welders do require; 1) The welding surface has to be relatively clean, not perfect, but not a lot of grease, paint, etc. (The wire just keeps 'afeedin' weather you have an arc, or not.) 2) The duty cycle may be as low as 20%, meaning the welder may shut-down to cool off. (My experience has actually been ~10 minutes on & ~5 minutes off. Not too bad, & I actually get almost 90% duty cycle at the highest current ratings by adding an external fan to help cool the rectifiers & transformer. Not shabby for a small welder!) 3) GET THE GAS CONVERSION! There is NO comparison between the fluxed wire, (So-so weld looks, lots of fumes, but cheap) The gas conversion gives MUCH smoother welds (& easier), & almost no fumes (Other than normal welding fumes). There is even less fumes than stick, because most sticks are self fluxed. Only drawback I have seen is the cost of gas & the wind (if outside) will blow the gas envelope away from the weld. Solution; block the wind with hand, body etc, &/or enlarge the gas envelope by turning up the flow. 4)Get one that handles larger than the 2LB spools of wire, you will change the wire much less. The century handles the larger spools (~10" in diameter, can't think of the weight right now!!). Changing the wire is not that big of a problem, just ALWAYS happens in the middle of a weld! (I use the .030" almost exclusively.) Obviously I love them! I even got rid of my old stick welder & use these exclusively! Happy Welding! (It's really cool to be able to build things!!)
