Tool Talk Discussion Forum
O/T '91 Park Avenue door trim removal ?
jCarroll
10-29-2006 19:38:23
I need to remove the driver side door trim to replace the headlight switch. The only screw I see is one on a small plate around the door handle - think it lets you get to the handle fastener.
After that, how does the door trim come off. I'm willing to try "whatever" but if someone knows what and where to pry I would appreciate the advice.
Thanks
bradk
10-29-2006 20:33:09
 Re: O/T '91 Park Avenue door trim removal ? in reply to jCarroll, 10-29-2006 19:38:23
One screw is at the lower corner marker lamp.Pry it out & you'll see a screw.The others are under the power window master switch.Insert a small flat blade screw driver in the slot at base of switch to release a spring clip.The rest is prying carefully to release fasteners.~brad
jCarroll
11-02-2006 16:58:46
 Re: O/T '91 Park Avenue door trim removal ? in reply to bradk, 10-29-2006 20:33:09
Thanks for the "right-on" directions. Did the whole job in 58 minutes (replacing the headlight switch) - and nothing got broken.
Thanks again.
