Building air compressor
john r
12-06-1998 19:16:59
i would like to make a air compressor or air pump from a 360 ford engine. has anyone any experiance,advice or sugestions. thank you
Clipper Crawford
12-20-2000 08:17:32
 Re: building air compressor in reply to john r, 12-06-1998 19:16:59
We are looking for a SullAir Two Stage 900/350 Compressor manual and Parts. If any one can help please contact Clipper Crawford at Dixie Drilling 205-849-1727,Fax 205-849-1726 or e-mail me at [email protected].
Thank you Clipper Crawford Service Manager Dixie Drilling
Clipper Crawford
12-20-2000 08:16:34
We are looking for a SullAir Two Stage 900/350 Compressor manual and Parts. If any one can help please contact Clipper Crawford at Dixie Drilling 205-849-1727 or e-mail me at [email protected].
Mike
12-07-1998 12:39:54
: i would like to make a air compressor or air pump from a 360 ford engine. has anyone any experiance,advice or sugestions. thank you
Yeah, seen one once. I forget which engine it was made fron though. It was a two stage unit set up as five low side and three high side cylinders (a V-8) and did quite a job. It had a heat exchanger (radiator) that was half for the block cooling and half for interstage air cooling. Don't have the slightest idea what it cost.
It's more common to use the engine block for a vacuum pump from what I've seen.
Either way it could get expensive to do the job correctly.
DC Dale
12-10-1998 20:48:55
 Re: Re: building air compressor in reply to Mike, 12-07-1998 12:39:54
: : : i would like to make a air compressor or air pump from a 360 ford engine. has anyone any experiance,advice or sugestions. thank you
: Yeah, seen one once. I forget which engine it was made fron though. It was a two stage unit set up as five low side and three high side cylinders (a V-8) and did quite a job. It had a heat exchanger (radiator) that was half for the block cooling and half for interstage air cooling. Don't have the slightest idea what it cost.
: It's more common to use the engine block for a vacuum pump from what I've seen.
: Either way it could get expensive to do the job correctly.
The Ford V8 compressors are SmithAir's , Out of Bowling Green , Kentucky . They are popular with rental yards, check around and see if some one rents them around yo and take a look....
john d.
12-10-1998 05:24:34
I rented a pneumatic jackhammer about 10 years ago that was powered by a Ford V8 which used one bank as the engine for power, and the other bank of cylinders for the air compressor. I would suppose that conversion parts are available somewhere!
john
05-07-2001 15:52:51
 Re: Re: Re: building air compressor in reply to john d., 12-10-1998 05:24:34
I,m building my own compressor from a 2.9 ford now. Ive seen others recently and I,m on the right track. I need alot of air. I,m not scared at all to continue this project. although money is tight
