Tool Talk Discussion Forum
AC stick welding sheet metal
Stan in Oly, WA
10-28-2006 17:22:04
Because of the lively exchange earlier this week about the best way to weld 3/32" thick metal with an AC stick welder I decided to put my money where my mouth is and get out an AC welder and try it. I used a Hobart Stickmate AC/DC welder set to the low AC range (30-170 amps.) This is an adequate, nothing to write home about welder. It uses a moving shunt to control current rather than the system of taps that a Linoln buzzbox uses.
My electrodes were 3/32" 6013 out of a freshly opened box of Harbor Freight's Quick Strike brand, and some funny 3/32" 6011 of an unknown brand that are only 12" long. These 6011 may be moisture damaged because they don't burn smoothly until about 1/3 of the rod has burned off. When I did the test weld, I first burned off half the 6011 rod on a piece of scrap. The 6013, which is made in India, performs much like every other 6013 I've used (probably 12-15 different brands or sizes altogether.)
The metal I welded was only about half the thickness of the metal Kestrel wanted to weld---about 3/64 where his was 3/32. My thought was that thinner metal wouldn't invalidate the results, but thicker metal would.
Despite having all good connections and the work clamped onto a grounded steel work surface, I could not get the 6011 to strike until I turned the current to just over 40 amps. The 6013 was slightly easier to strike at lower amperage settings, but not much. I know from past experience that both these rods strike and run well at much lower settings on DC current from good quality welders---but that wasn't the test.
The 6011 made messy but adequate welds and did not burn through except at the end of the weld at the edge of the metal if I wasn't careful. The 6013 did not produce adequate welds on metal this thin. If the current was adjusted low enough to prevent burn-through, then the bead had the rolled appearance characteristic of insufficient penetration/fusion. If the heat was turned up to get the bead to flow out, it burned through the metal in too short a time to get much down.
I'd describe the results as inconclusive or call the 6011 better by a narrow margin. Both types of electrode would have performed better on thicker stock. I'd like to try it again with 3/32" sheet metal.
Stan
souNdguy
10-31-2006 12:20:05
 Re: AC stick welding sheet metal in reply to Stan in Oly, WA, 10-28-2006 17:22:04
Preface: I'm not a 'welder' Though i do own 2 AC stick welders.
I have a 70a Campbel hausfeld ac stick welder... got it from walmart. it has a 30amp setting, and a 30-70a 'auto' setting. I've had this one for 4 years now I think.
I also have a hobart stickmate xl 235a ac welder. i just got this one...only a few months ago.
I've welded plenty of sheet metal with the CH welder. Thin stuff.. like 'for sale' sign thin.. etc.. poster board thin.. not sure of the gauge.. but stuff you can cut with tin snips.
I use the cheapy CH welder, set to 30a and a 1/16 rod. Unless i -want- it to burn thru.. it doesn't On slightly thicker sheet metal.. or where it is tacked to something substantial, i occasionally use the 5/64 rod and move to the 70a setting.. or stay with the 1/16 rod.. depending on the thinner metal. On the 70a setting.. I have to be carefull not to blow holes in the thin metal trying to get penetration to the thick metal. Sometimes a make a good penetration pas on the 5/64 rod, and then fill in with the 1/16 to make the weld seam look good.
Soundguy
T_Bone
10-29-2006 09:36:11
Hi Stan,
It's all in the technique that is applied.
Example: I can weld a 22ga x 30" wide SS counter top without warping the SS. I can also finish that weld to blend into the surrounding SM to where the average tradesmen could not find where I made the weld. However have one of our metal finishers come to look at my work and he would immeadatly put his finger down on top of my weld seam.
I've also welded a fair amount of pipe. I've had numerous compliments on how my pipe welding looks, however have a pipefitter/welder look at my work and he would say amature and righty so as I've seen pipe weldors that would put me to shame in a heart beat.
I've also taught welding to alot of students in groups less than 5 people and turned out some really great weldors, however put me in a classroom with 20 students and a good instructor like yourself would put me too shame.
So yes 7014, 7024, 6013, 7018 can be used to weld SM on some joints with good results but 6011 or 6010 DCEN is a much better choice over all for SM welding. What is just as important is using the correct welding technique.
There's also times where Mig is the best choice for the joint design.
Or carbon arc where high speed seal welding is needed.
In a SM shop enviroment, stick is really not a productive procedure for most welding. However in SM field work, stick welding works well 99% of the time as it's much faster overall.
T_Bone
TomTX
10-28-2006 19:48:18
Stan, try some brand new 7014 rod on DC and you will be very surprized at how good it penetrates and how easy it is to remove slag. Lincoln classifys it as a "fill/freeze" rod. I use way more 7014 1/8 rod than any thing else. Tom
135 Fan
10-28-2006 23:59:16
 Re: AC stick welding sheet metal in reply to TomTX, 10-28-2006 19:48:18
Just to clarify the original topic. We were discussing what would be the easiest electrode to use for welding thin sheet metal with an AC buzz box welder. In almost all cases DC is much easier to weld with. I had suggested 3/32 6011 because I thought the material was galvanized. It wasn't but it was painted. What works for some people may not for others. No two welders use the same technique. 7014 are stronger than 6013 but usually need more heat and have a thicker flux that has iron powder in it for faster deposition. 7024 are called jet rod because you can weld faster with them. They are almost the same as 7014 but have even more iron powder in them which limits them to flat and horizontal welding only, hence the "2" in the 70"2"4 classification. Stan was experimenting with what rods would work better. It's not a contest, if it works, it works. All welding takes a lot of practice! I would like to watch someone stick weld 5 or 50 thousands inch thick steel. If you really want to try something harder, try taping the stinger on the end of a 4ft. long broom handle and reaching in a vessel to weld a tray in, that can't leak or have undercut, and has to welded with 7018 while your turning the vessel at the same time to keep the weld at the bottom. Not fun! Worse yet try crawling 16ft. inside an 18 inch pipe to back weld a fire tube with the ends cut at a 45 deg. angle. You can't move let alone weld and it has to pass X-ray! You wouldn't want to practice this. The point I'm trying to make is that it is good to try different techniques. What might be easier for one person might be harder for another. Different makes of rods behave differently. Lincoln 6010 was the only 6010 to even consider buying for many, many years because other brands would finger nail [coating wouldn't burn off equally and looked like a finger nail]. If you can master welding enough to fix and build your own stuff you can save a lot of time and money and get great satisfaction in knowing that you did it yourself. The best tip I can give is to make sure that you can see what you are doing. I've seen lenses on helmets that were so dirty, you might as well of closed your eyes. That said never use less than a #10 lens unless you are welding very small amounts of thin material with very small rods. If you can't see, you could get a magnifier lense, but don't get a strong one. They can be hard on your eyes too. You only get one set! Protect them. Hope this inspires people to try different methods. Sometimes you will be amazed at the results. Dave
Stan in Oly, WA
10-29-2006 13:41:34
 Re: AC stick welding sheet metal in reply to 135 Fan, 10-28-2006 23:59:16
Hi Dave,
Thanks for clarifying the terms of the original question. I know I'm going to sound pi$$y saying this but I'm often puzzled at the amount of energy that's wasted on this forum by people who have failed to read the original question and then give great answers that are essentially irrelevant. If someone asks what is the best way to weld something with a low OCV AC welder it is perfectly reasonable to answer that it would sure be a lot easier and better to do that particular job with O/A or TIG, or whatever, or tell him/her that that particular job is better left to an experienced professional. But I never can figure out what purpose is served by answering a question like "What is the best electrode to use with my Lincoln AC buzzbox to weld X?" with "6010 on DC+." As long as the answer advises the asker to do something he/she can't do, why not go all the way and suggest calling Bill Gates at his private number and seeing if he would like to do it?
Funny, I expected to feel a lot better after getting that off my chest.
Your observations on the quality of the 6011 rod I was using were typically precise. I'd heard about dunking 6010 or 6011 before using either of them for cutting metal (the arc welding process that comes closest to vandalism, in my opinion) but only rumors about old timers who wetted 6010 before welding with it. Within the past month there was a discussion on this forum (or maybe the AWS forum) about 6010 being worthless after getting wet and then drying out. I'll try to find it.
I'm looking forward to continuing my experiment with 6011 and 6013 rods on thin metal, but I'm not quite interested enough to spring for a package of 3/32" 6011 just to know I'm using fresh rod. I hope I can find some that's free. Too bad that using 1/8" electrode won't (unequivocally) provide the information I'm after because I've got an enormous amount of that. Same with using a better welder. I have an old, copper wound Lincoln Idealarc that welds nicely even with some terrible, unknown brand 6011 I was given that is the worst rod I've ever used. But that would prove nothing about what you can do with a cheap AC welder. I'll keep you updated.
By the way, all the 3/32" rod I'd ever seen (except for some SS) was 14" long until I was given an open can of the 12" 6011 I talked about. There was some 12" 6010 mixed in with it. It's not very good either. Lincoln, Hobart/WeldIt, Easy Arc, Radnor, and a number of minor brands all put out 14" 3/32. My experience in welding is neither long nor wide, though.
All the best, Stan
T_Bone
10-30-2006 08:32:38
 Re: AC stick welding sheet metal in reply to Stan in Oly, WA, 10-29-2006 13:41:34
Hi Stan,
Well had you been in the SM trade you would see just how relevant my last response is.
In SM welding light gauge welding is considered any gauge below 10ga or 1/8" thick. 10ga and thicker is condiered heavy plate in the SM trade. 14ga/.085 is really close to 3/32" thick so it's not vary challenging to a experienced SM weldor that commonly welds 18ga/.055 with stick.
As I stated welding technique and joint design plays a huge roll in how light of gague can be welded with stick. Using the back step welding technique allows for more amperage to be used for a smoother weld apperence as well as less chance of porosity.
As to electrode there's only 2 common electrode choices, that being 6011 or 6010 DCEN. Although both electrodes can be used with AC, 6011 is a good choice for AC vs 6010.
Other electrodes can be used, 6013, 7014, 7018, 6027 but are a very poor choice for light gauge SM stick welding.
As the SM gauge become thinner then using 6010 DCEN works well or 6011DCEN. I personally like 6010DCEN more than 6011. Although AC can be used it becomes a least favorite choice.
Another note is I find that at the amps I weld SM at, I usually have to throw away the last 4" of electrode as it's ruined from the heat.
T_Bone
Stan in Oly, WA
10-30-2006 15:24:22
 Re: AC stick welding sheet metal in reply to T_Bone, 10-30-2006 08:32:38
Hi Ken,
Not you, for goodness sake! I've never read an irrelevant posting by you, and if I did I'd assume that I was misunderstanding something. You are admired as much for the clarity of your thinking and your answers as for the extent of your knowledge.
There was no point in my complaining about people who fail to pay attention to what was actually asked before launching into a useless answer. It doesn't harm me any more than I'm harmed by people who are talking to themselves as I pass them in a public place.
Anyway, instant karma already got me on that little outburst of gratuitous ill will. I was so startled to read your response "Well had you been in the SM trade you would see just how relevant my last response is" that I rushed to reply immediately and missed the deadline on bidding on a new Bernard Shortstub 400 amp electrode holder on eBay. Bidding ended with no bids on it so I'd have gotten it for the $5 starting bid and $5 shipping. The first thing I thought when I glanced up at the clock was "Oh no!" which was immediately followed by "Well, serves me right." I know how these cosmic things work. COL (crying out loud)
All the best, Stan
T_Bone
10-31-2006 05:54:53
 Re: AC stick welding sheet metal in reply to Stan in Oly, WA, 10-30-2006 15:24:22
LOL Stan, I thought you might be just having a bad day and it was my turn in the barrel :)
I did that too a stock a couple weeks ago and I'm still upside down in it. :<{
T_Bone
135 Fan
10-29-2006 16:32:04
The questions seem to go off topic sometimes. In my experience, the people that are the best at doing something, are also the most humble, and will only tell you if you ask them. I always consider it a compliment if someone asks me about something I do. I give advice based on my own personal experience or from people that know for sure. As far as rod lengths, I've always seen 3/32 in 12 inch, 1/8 and 5/32 in 14 inch, 3/16 and 1/4 inch in 18 inch. However 3/16 is available in 14 inch to get into smaller spaces and I've seen longer rods than 18 inches for long flat position welds. Shorter rods are easier to control especially in the small sizes.
Most shops don't use 6011 because they have DC welders. With the newer 5P+ rods from lincoln, you rarely need to wet them. The regular 5P would sometimes get too dry. It took a while for the 5P+ rods to get approval up here when they first came out. They are much nicer to use.
Try your 1/8 6011. You can turn them down a lot. I worked in a shop and we welded all the checker plate seams with 6010 for a flat weld with the least amount of warping. A lot of times we'd use 3/16 at a lower heat and you could weld about 18 to 24 inches per rod. You're basically pulling the puddle along.
I was looking in the archives forum and there are a lot of extremely knowledgable welding people on here. One of the questions was how to tell what polarity you're on with DC. 6010 is the rod to check polarity. I was using a Lincoln portable and my rods were acting real funny even though the cables were hooked up right. For some reason the polarity got reversed in the welder itself. I always recommend getting a name brand welder like Lincoln, Miller or Esab. There are some other less popular brands that work well also. For a low open circuit voltage machine I personally prefer a Lincoln over a Miller even though the Miller has infinite current adjustment. I find it easier to strike and hold an arc. Old Hobarts are supposed to be good. I hope I don't start a big debate. All a person has to do is try an industrial DC machine and they'll be wanting one. Buzz boxes are very good for occasional repair and fabrication but take more time to master. Current rods make it easier. There sure is a wealth of information on this forum. I've learned a lot and also read some bizarre stuff [brazing a gas tank that leaks with it full of gas] as well. I enjoy corrosponding with you and the other people on here. It makes me think! I haven't done that for a while. Let us know how the experiment goes. Dave
Bud in NC
10-29-2006 05:08:16
You forgot to mention making a mirror weld at arms length with 2 9018 rods tacked together and turned 180� to reach the back of a boiler tube or hanging upside down 200 feet in the air or welding in a spot so close you can't focus your eyes on it. Also, don't forget all the times you're in a close spot ad set yourself on fire or have a lump of slag burning a hole in your hide and you can't move! We had a mechanic who'd just gotten his certs for carbon steel TIG in 6G position who was b*tching about the test booth being "too cramped"! He got an education on "cramped" - decided he'd find another vocation, too.
I've still got a nice collection of scars from jobs like that - and it's been 20 yeas since I did that for a living.
135 Fan
10-29-2006 10:34:22
 Re: AC stick welding sheet metal in reply to Bud in NC, 10-29-2006 05:08:16
I've got little scars on my arm that make me look like I did a lot of bad drugs. LOL. Being on fire isn't so bad as long as you can finish the rod before you put the fire out. I was cutting pipe overhead that had some kind coating inside and it caused hot slag to drip down the back of my neck. Had a scab about 1/2 an inch thick. Got a big ball of spatter hardfacing that went in my boot and caused a third degree burn. No matter how fast you can take your boot off, it's not fast enough and if you shake your foot all it does is burn you more. Why would anyone in their right mind want to be a welder. Guess that's why they call us welder pigs or why there is a lot of grumpy old welders. [It's not that bad most of the time] Keep practicing. Dave
Bud in NC
10-29-2006 16:41:08
 Re: AC stick welding sheet metal in reply to 135 Fan, 10-29-2006 10:34:22
I got one of my more notable scars when I was welding in an Forced Draft Fan is a dirt burner when the guy above me dropped a slag ball - down my collar, down my back and setteled into my back when it got to my belt. OH YEAH!!!! THAT got my attention....but I still wasn't gonna leave my welding for someone else to finish. I was lucky - my girlfriend at the time was an EMT so she was able to extract the slag when I woke her up at 4 AM. You're right - nobody with good sense would be an industrial welder!
But I enjoyed it....I guess it takes a special kind of brain damage, huh? It was kinda fun *after* the job when you'd made a weld nobody else wanted to get near.....then again, anyone with good sense would avoided those jobs, anyway!
135 Fan
10-29-2006 16:52:15
 Re: AC stick welding sheet metal in reply to Bud in NC, 10-29-2006 16:41:08
I've been on fire several times. You always try to finish the rod before you worry about your burning coveralls. The ONLY exception is when your crotch is on fire. Then you tend to want to put it out in a hurry. Nothing like experience! Dave
Bud in NC
10-30-2006 03:11:24
 Re: AC stick welding sheet metal in reply to 135 Fan, 10-29-2006 16:52:15
And when you swat the fire on your crotch while wearing a heavy welding glove, you find a brand new problem.....hurting and smoking!
135 Fan
10-29-2006 17:12:36
I remember working with a couple guys in a light rain. We were putting a couple extra supports for a platform for a truck filling station at a chemical company. That angle iron was clamped and I somehow got it tacked so I could take the clamp off. I couldn't see because the lense was wet. One of the other guys suggested taking the lense out of the helmet and holding with one hand and welding with the other. He said just strike an arc in the corner and weld in a straight line across the seam. I took his advice and struck an arc and did a nice straight weld. I was proud of myself ... . It was a perfect 6010 bead in a nice straight line ... at 45 degrees to where the joint was! We ended up getting the crane driver to put it in the shop. Thought this might humour you. A good welder is one who can fix his mistakes before the boss finds out. Dave
Stan in Oly, WA
10-29-2006 18:35:38
 Re: AC stick welding sheet metal in reply to 135 Fan, 10-29-2006 17:12:36
Hi Dave,
Funny that you should mention trying to weld w/o eye protection by holding your hand between your eyes and the arc. I'd never done that before and had only actually heard of anyone doing it once before. But yesterday after I finished my trial welds with 3/32" rods and thin metal, I took a couple of postage stamp sized metal clips I'd grabbed and tried to weld them to a scrap of mild steel plate just that way. I was not successful, but I was in a hurry and didn't have the time to keep at it until I got it.
I've set myself on fire a couple of times---once when I pulled an O/A filler rod out of the weld puddle and touched it to the sleeve or my cotton shirt, once when the sparks from an angle grinder set my shirt on fire just north of my belt buckle. In each case the fire was so insignificant that I was able to get to a good stopping place before having to deal with it, but, you know, soon.
A small but painful injury occurred once when slag from O/A cutting bounced off the concrete and into my left boot right between the laces and past the left side of the tongue. I had warned plenty of new student welders (mostly artists) about the danger of wearing synthetic fiber clothing when welding, but it had never occurred to me that it applied to socks inside leather boots. It does though. On the other hand, it's the one place where it doesn't much matter if the clothing melts and sticks to your skin. It's not going to be any hotter than whatever melted it, and the event is going to be pretty much over by the time you get your boot off. But here's the part that I feel makes it qualify as a valuable learning experience. Within less than five minutes of the event, and against all my expectations, I was able to establish conclusively that this was not a once-in-a-lifetime experience. Same foot, same place, I might even have been cutting the same piece of metal. The bounce was so precise that it didn't have to burn a second hole in my sock, and I have a single scar where I got those two burns. Just think of the things I might have to talk about if I'd been doing this for a long time.
All the best, Stan
135 Fan
10-29-2006 19:00:21
 Re: AC stick welding sheet metal in reply to Stan in Oly, WA, 10-29-2006 18:35:38
Thanks Stan for mentioning that. I guess I wasn't clear and it's important. I was holding the lense with one hand and welding with the other. Never weld without eye protection. Some people tack with MIG but hide the arc behind the nozzle. The worst pure accident I've ever heard about was in school for the gas welding test. One of the guys welding would rest his rod on his stool to move his hand up on the rod so he wouldn't burn his hand. Pretty common. Well one time he went to do it and put the red hot rod on his mid section and pierced his testicle. I can't say for absolute certain that it happened but seems very likely that it could. Especially when your concentrating on getting a good weld. Makes a person cringe just thinking about it. It never fails when you get burnt that you keep getting burnt in the same place. It's like a magnet or something. Spats on boots are a good thing. Dave
135 Fan
10-29-2006 19:07:23
 Re: AC stick welding sheet metal in reply to 135 Fan, 10-29-2006 19:00:21
I just thought of something very important. I think it has been mentioned before but I'll mention it again. Never have disposable lighters or matches in your pocket when doing any welding, heating or cutting. They are like a bomb ready to go off. Some people have had serious injuries as a result. Dave
mph
10-28-2006 19:19:00
Well if you want to brag: I've [stick] welded down to .50.oo thousand of an inch thick,but I was welding every day and had very good equ. And at that time I did't have the 35 + years I have now. Now I own 2 millers big 40 and a roughneck ie, I still can weld THIN metal all it takes is practice. When I started welding their was no wire feed. I think that STICK welding is a art now anymore,any one can run a bead with a wire feed and it sure looks pretty, but to me has not impressed me any [on heavy equ.].Not that it don't have its place. Just that some of the REPAIR work I've done, some one thought that a wire feed was the way to go, NOT! Note I only use good rod made in the u.s.a.
135 Fan
10-28-2006 18:17:39
Glad you tried it. If the 6011 were from a fresh box, they probably would have worked a little better. I thought all 3/32 rods were 12 inches long. 6011 usually don't get moisture damage. The opposite is true, they get too dried out. 6011 is an AC version of 6010 and has a cellulose type coating that requires some moisture. In fact sometimes 6010 can be dunked in water to improve their welding qualities. Just to confuse you even more, you could try it with the 6011. Just shake the water off and let them sit for a few minutes and see if they strike and weld better. Try going down hill moving the rod quickly up and down as you go. Turn your heat a little hotter and go fast. It takes some practice but you can go pretty fast. Do a little experimenting. You might be surprised. Dave
old
10-28-2006 18:05:48
I just welded up some exhaust pipe today useing my lincoln buzz box and 75AMPs. I used 6013 rod and it did a good job with no burn throughs. The rod I used was 5/32 rod. But I have been welding for 30 plus years now
dan hill
11-04-2006 04:11:17
 Re: AC stick welding sheet metal in reply to old, 10-28-2006 18:05:48
I use Stainless rod on new exhaust pipe.Stainless seems to run smoother on problem jobs.
Rauville
10-28-2006 20:08:22
The toughest welding job I encounter are those cheap @&*# tombstone style round bale feeders for horses that TSC sells. They fall apart within 6 months, and the air turns blue around me when I'm trying to fix them up. But, I will say that my 50+ year old Marquette AC welder and 6011 1/8" rod can still glue them back together.
