Tool Talk Discussion Forum
Power washer question
Kmiller
10-28-2006 16:52:54
My dad has a 6hp Generac power washer but can't get the soap pickup hose to work. It sprays fine but hasn't ever picked up anything. Any ideas what to look for? I've got it here at my house and told him I'd see if I could get it to work for him.
Tnx,
Kerry
muski
11-14-2006 07:16:36
 Re: Power washer question in reply to Kmiller, 10-28-2006 16:52:54
bleach is popular with power washing companies who clean houses before painting
Don L C
10-29-2006 19:28:16
I guess you guys know that the washer will only suck soap using the low pressure nozzle..... then go back over your work with a turbo nozzel..... .
deanop
10-29-2006 16:41:31
I think I've got a similiar pressure washer with 5.5. briggs...It doesn't draw well either...I've had so so results...I did buy a kit at northern with had a turbo nozzle and like 5 other nozzles...the soap nozzle sometimes will draw at real low rpms...I think the fellow who chimed in with the upstream adapter is your best bet...I've pretty much given up on mine as far as soaping..deanop
Ryan - WI
10-29-2006 04:30:53
Not sure if you want one but they do make an adapter to allow for soap at high pressure too.
Stumpalump
10-28-2006 17:17:25
Not familer with yours but on my washer you have to pull out on the end of the wand. This puts it in a low pressure spray mode. It has less pressure but more water volume. Somhow this lets it suck soap into the tube. It pulls in slow but the soap will eventually draw up the tube into the low pressure spray. In other words in high pressure mode it won't pull soap.
blwd005
10-28-2006 17:16:39
They will only draw soap if you have the low pressure tip on the end of the gun, or have the adjustable nozzle turned to low pressure
kmiller
10-28-2006 17:38:31
 Re: Power washer question in reply to blwd005, 10-28-2006 17:16:39
Thanks guys, I'll take a look at it. I know I can turn it to change from a fan spray to a sharp (very hard) stream. I'll see if I can pull it out.
On the same machine, there's a big knob with a spring on it on the pump. What does it do? Does it regulate the pressure or flow on the pump? It looks like it's screwed all the way in right now.
Thanks,
Kerry
135 Fan
10-29-2006 00:23:38
 Re: Power washer question in reply to kmiller, 10-28-2006 17:38:31
That knob is the pressure adjustment. Is there another small knob to turn for soap? Just a thought. Good luck. Dave
kmiller
10-29-2006 17:50:26
 Re: Power washer question in reply to 135 Fan, 10-29-2006 00:23:38
It worked, sorta. In the low pressure mode it did suck the soap out of the bucket. There's no adjustment for the line that goes into the bucket. I mixed a cup of laundry soap with about a half gallon of water, that wasn't enough apparently, it gets pretty diluted with the water from the hose. It's not exactly like a car wash, but it did a pretty fair job on the siding. I'll have to experiment with the soap, what do you guys use???
Thanks for all your help, I'm getting it figured out, I think.
Kerry
kmiller
10-29-2006 12:18:51
I haven't found an adjustment for soap, but I'm going to find that low pressure mode today if I can! I assumed that big knob was an adjustment for the pressure, I'll look around to see if there's another ajdustment for soap but I don't think there is one.
I found it's also deadly on wasp nests - I guess it's true what they say about boys and their toys, this thing is pretty cool. First I'm going to attack the siding on the house then maybe my dirty truck.
Thanks for all your help, guys!
Kerry
Victoria, TX
