Trailer light connections
Ray Matchell
03-28-2001 12:19:26
Not sure if this is the right board to ask this question or not. I recently purchased a trailer for hauling my Farmall around and I'm not sure about wiring the brakes. Have a blue wire and a white wire, which one is which?
tools
03-28-2001 16:48:01
 Re: Trailer light connections in reply to Ray Matchell, 03-28-2001 12:19:26
Mine has the same two wires. Beings it's DC and it's only operating a selonoid, doesn't matter. However, convention has the blue being the one that gets + voltage from your brake controller, the white one goes to ground. On the trailer, neither one should ground out, however.
Tools
BFO
03-28-2001 12:30:49
If you're talking about at the back of the truck, I would say the blue is "brake power", and the white is ground. Take a 12v testor and make sure though.
boman
04-01-2001 21:42:32
 Re: Re: Trailer light connections in reply to BFO, 03-28-2001 12:30:49
have an old car hauler that also has some blue wires for the brakes. wires have been torn apart. no connector, etc. can anyone tell me how to wire them back up? do i have to have a battery pack of some sort, or can they connected to a connector from vehicle? tx for any info
BFO
04-02-2001 20:54:57
 Re: Re: Re: Trailer light connections in reply to boman, 04-01-2001 21:42:32
Start by determining which wire is "power" from the truck. Then, on the trailer side match the plug terminal and follow that wire back to each wheel. Connect one of the wires on each brake to the power. Then do the same with the ground. HTH
boman
04-03-2001 08:30:12
 Re: Re: Re: Re: Trailer light connections in reply to BFO, 04-02-2001 20:54:57
THIS TAKE CARE OF BLINKERS. STOP LGHTS, ETC? ANND BY THE WAY, TX FOR RESPNSE
BFO
04-03-2001 11:20:35
 Re: Re: Re: Re: Re: Trailer light connections in reply to boman, 04-03-2001 08:30:12
No, that was just for the brakes. You'll have to do similar for the turn signals and running lights. It's easy enough with a 12volt tester on the truck plug, just take your time and do one circuit at a time. Make sure you have a proper ground for the lights (usually to the frame on both truck and trailer). For the brakes though, I run a separate ground all the way to the negative terminal on the truck battery. Not as bad as it might seem, good luck.
boman
04-09-2001 11:35:07
 Re: Re: Re: Re: Re: Re: Trailer light connections in reply to BFO, 04-03-2001 11:20:35
tx a lot. Simple now that i think about it!
