Tool Talk Discussion Forum
Miller Maxtron 450
Chris611
10-25-2006 07:35:52
Can you guys tell me what you think about a Miller Maxtron 450 with an S22-A wire feeder? I plan to run on single phase through a 100 A circuit. Seems like a good machine. It doesn"t have pulsed MIG, but I understand you can add it later. If you guys have any knowledge of this machine, good or bad, let me know.
Thanks
Chris
135 Fan
10-25-2006 22:24:20
 Re: Miller Maxtron 450 in reply to Chris611, 10-25-2006 07:35:52
Miller makes good industrial welders. I prefer a Lincoln buzz box but you're looking at something way better. Most big welding shops use Miller welders. For all practical purposes you don't need pulsed MIG. It is used at high heat settings and voltage in spray transfer mode for maximum speed and good penetration without burnthrough. Most MIG is done in short circuiting mode. That is why pulsed MIG is available on a 450 amp machine. If you want to weld thinner material you can use smaller wire. Thats what they use for auto body work [.023]. Miller has good wire feeders. A four drive roll is best but not neccesary. It allows you to use a longer gun. Most shops use a Bernard easy feed gun because it is easy to change the liner for different size wires. The quick change drive rolls are nice and if they still have a feeder with a slow start feature it is really nice. It feeds slow at the beginning of the weld so you don't get wire stubbing and makes it easier to have a nicer start. If you are going to use higher settings, I wouldn't want your power bill. Miller welders are top of the line and hold up good in a shop setting. I wouldn't hesitate to buy one. You could check if Lincoln has an equivelant and compare price. Miller's are more popular MIG machines up here. Hope this helps. Dave
NC Wayne
10-25-2006 19:55:10
We bought a maxtron 450 and a feeder off ebay a few years ago for the business. We mainly needed something single phase,with 100% duty cycle, to use on our homemade buildup machine. I can tell you our machine has run 6 to 8 hours a day, at 300 amps, running .052 wire out of a 500lb drum, on several occasions with no problems. I remember another time I ran nearly 100 lbs of .045 through it over the course of 2 or 3 days doing some hand work and again no problems. So, to answer your question, the Maxtron 450 has never let us down and, in my opinion, is a GREAT machine. I believe the feeder we've got is like an S22A or something like that. It has the capability to use preprogrammed cards for automatic operation and also has, I believe, five different weld settings you can program into the machine itself and manually toggle between. We don't use any cards butI love having the different manual programs because I can get it set like I want it for different thickness materials and simply toggle through the programs when I encounter each without messing up the settings for the others. Basically it eliminates having to "dial it in" every time. As for the pulsed MIG, I've heard it's nice but personally I don't se a major need for it. The main advantage is it makes it easier to weld thinner material by pulsing the current. Doing this allows the puddle an instant to cool before it pulses again preventing too much heat buildup causing the weld to burn through. Basically all you have to do is PRACTICE and use smaller diameter wire and a lower current for thinner metal and larger wire and higher current for thicker metal. Do that and you shouldn't have any problems with anything you run across from 22ga sheet metal to structural steel. Better yet get a job in a place building truck bodies, using old Miller Dialarc machines, where the welds had to be feathered in and pretty or you ground and polished them til they were. Often times they'd make a mistake in the sizing and when the panels were bent and fitted there's be 1/4 inch gaps between the panels that had to be filled. Needless to say it doesn't take much grinding before you learn how to make the welds, even the ones filling a 1/4 gap, nice enough from the start that all you have to do is give them a swipe to polish....welding is alot easier than grinding... Good luck with your new machine, I think you'll be really happy with it.
