Hi Paul, Alot of the below info I posted about 5yrs ago and have updated it today: UPDated 10/25/06 All the welding processes works well welding Sheet Metal, under 10ga (1/8") and down too about 22ga (1/16"), Oxy/Acet, Mig, Tig, carbon arc, plasma arc and stick. From 22ga to 30ga then Oxy/Acet., Tig, carbon arc and plasma arc works well. Which welding process is best suited for an application is determined by gauge, joint design, joint preparation, electrode type and technique. With this is mind it take a book written on the subject to cover all the possibility's for a given job so we'll only deal with the task at hand. 14ga is approx .0745 thick average for carbon steel. The thickenss can vary from .0645 to .083 depending on the mfg and metal type to be with-in industry accepted standards. 6011 3/32" using AC is a good choice providing you keep a tight joint fit-up and use the back-step welding techinque. 6010 3/32" DCEN, DCEP or AC for galvanized SM, DCEP for mild steel SM, AC only if you don't have DC, again using the back-step technique. 6013, 7018, 7014, 7024 is a very poor electrode choice as the flux is too heavy for the welding techinque required on SM. The back-step techinque (welding from left to right) is where you deposit the weld puddle then quickly move out of the weld puddle to the right 2 rod diameters then return to the weld puddle to cover 1/2 of the existing bead for another weld deposit, thus repeating until a smooth bead is layed in. What this does is allow for the molten metal to slightly cool before more metal is deposited thus a cooler weld is achived that helps limit warpage and burn thru. On a SM lap joint, to help control warpage, tack weld every 1-1/2" using 6010/6011 3/32" at 20amps higher than normal welding amps. Skip weld vertical down if possible. On a SM Butt joint tack weld every 1-1/2" leaving a root opening equal too 1/2 of the base metal thickness (for joint shrinkage) and use a chill block on the back side while skip welding vertical down. Welding SM requires good joint fit up. It's all most impossible to weld SM with poor joint fit up. A 1/2" standing seam joint is the best overall joint design for SM. Turn 1/2" of metal vertical on both sides of the joint then clamp the standing seams together, then tack weld, then weld. You must skip weld, about 3" long then skip 14", most SM reguardless of joint design or welding process used or techique applied, to keep base metal warpage to a minimum. If you don't have 14" to skip on then let air cool for 5min between welds. T_Bone
