Tool Talk Discussion Forum
Rust on jointer table and fence
R.J.
10-24-2006 20:31:31
Bought jointer at auction hasn`t been used in a while, has surface rust on table and fence.
What to use to remove rust?
Thanks R.J.
daves 40 acre
10-28-2006 09:41:02
 Re: Rust on jointer table and fence in reply to R.J., 10-24-2006 20:31:31
I have used a drill with a wire wheel, then applied some eurathane on table worked good haven't had any more rust
Bernoulli/OR
10-27-2006 15:59:42
3M surface conditioning discs - sort of like round rescue pads. I use the medium lightly then use the extra fine. You can get them in roloc kits for electric drills. I use 7" ones in a body grinder. Do not oil first. It will load up the discs.
Stumpalump
10-26-2006 13:04:39
My dad loaned his old table saw out when I was a kid and came back looking brand new. The guy said he took it apart and had the cast parts machined down at a clutch and flywheel shop. It was clean and perfectly square. He said he needed perfect cuts for an old woodie wagon he was restoring. Kinda extream but I'm just tossing it out there.
500sks
10-26-2006 06:20:36
After you have it clean use paste car wax to stop rust from forming. I did this on my table saw and steel bench a couple of years ago and they are rust free today.
Midwest redneck
10-25-2006 13:41:14
WD-40 and fine grit sandpaper should work. Also oil it with Heavy way oil, or chainsaw chain oil afterwards to prevent rust.
Ryan - WI
10-25-2006 17:36:30
 Re: Rust on jointer table and fence in reply to Midwest redneck, 10-25-2006 13:41:14
If you oil the table on a woodworking machine I guarantee you will be cursing yourself for the next few months or years. The oil will remain on the surface and get sucked into your material. This will prevent stain and finish from adhering well. Instead use a good paste wax. Car wax or floor wax will work well.
Midwest redneck
10-26-2006 15:18:04
 Re: Rust on jointer table and fence in reply to Ryan - WI, 10-25-2006 17:36:30
Good point, I was thinking of metal working bandsaws, I am a machinist.
varmint
10-25-2006 09:29:16
steel wool & vinegar will work.
Dale in WV
10-25-2006 08:52:59
The one I brought home last month was more dirty than rusty -- but cleaned up well with a good soaking of the PB blaster and followed up with a random orbital sander on the bed and fence.
Tip
10-25-2006 07:12:07
PB Blaster, steel wool, 3M pads, and a razor blade. Put a coating of PB Blaster across the top and then "plane" it with the razor blade. Wire wheels and sanding will alter the surface and leave scratches that are hard to get out. The razor blade method will take all the rust off and leave the top looking old but refreshed. You can then use the 3M pads and/or steel wool to make it look as new and shiny as you want.
When you are finished, wax the top and you'll be good to go.
Regards, Tip
jpuleo
10-24-2006 22:40:48
Ive done it alot. A opital sander with 100-200 grit paper. Splash lots of water down and wet sand away. it will come beautiful. just towel it off and gve it a wax and your good to go.
Timothy Phipps
10-24-2006 22:02:11
One of my neighbors is a cabnet maker with a very creative streak. If he picks up a used tool with rust on it, he just uses the heck out of it to scrub the rust off. arter getting it clean, he uses the paste floor wax on it. I have never seen any rust on his normal tools
Tim in OR
JOHN HARMON
10-24-2006 21:36:17
I would use my Orbiting Sander with an 80 Grit Pad to shine it up and then give the surface a light rub down with Kroil Oil on a Rag.
Marks8N
10-24-2006 20:58:48
3M makes a 2" sanding system for gasket removal etc. they 1/4 turn to install and remove, NAPA has them in a brown pad and 50 grit roloc bristle disc and the box also says rust and paint removal. I use this all the time to referbish gasket serfaces and for rust removal on steel, cast iron, aluminum, etc. you can get a nice finish to the metal also.
504-1
10-24-2006 20:53:04
steel wool and P B Blaster.
