Tool Talk Discussion Forum
Grain moisture tester
Ohio Case
10-23-2006 16:38:16
Who makes a good, accurate, grain moisture tester? Mediumn price range?
Thanks
trw
10-24-2006 10:34:36
 Re: Grain moisture tester in reply to Ohio Case, 10-23-2006 16:38:16
We have one that we got from John Deere about 12 years ago. It is the one that you put the grain in it and screw the lid down. They have one that you just pour the grain in. It has been a very good tester. It even spent one winter in the field. I had set it on top of the cab of the combine after I got done testing the grain and I forgot about it until it was to late. The farmer found it the next spring, and we put a new battery in it and it worked fine. It can be calibrated to your local elevator, and can be used in many different grains. I think they still make one very similar to it. I think we gave about $150 for it.
Greg_Ky
10-23-2006 23:35:12
Motomco
RickL
10-23-2006 18:17:27
I have a dole unit
