Tool Talk Discussion Forum
What else is happening?
steve from mo -
10-22-2006 08:18:08
The ridgeboard is not the problem, since it only holds the raters apart and provides temporary support while you're putting up rafters. It can't hold the whole roof straight.
If you have a sag in the middle of the roof as compared to the ends, you also have a bulge (or less likely a sag) in one or both of the side walls. A chalk line will help you locate it. Then when you get the walls pulled in straight, and anchor the walls to the rafters properly, you will have a straight roofline.
