Tool Talk Discussion Forum
pto jackshaft
old bones
10-21-2006 16:06:36
i want to power a pto driven auger with an electric motor, leaving the pto shaft intact on the auger. i've got the motor (from the auger i'm replacing). i'm going to make a jackshaft and mount it on an axle for portability. i also have a shaft (with male pto splines) off my 37 sickle mower that was used to power a conditioner pulled behind the mower, but i hate to cut it down to use on a jackshaft. my question- where can i find a pto adapter to fit on a smooth shaft, held solid with a keyway or thru-bolt? this setup will feed my continuous flow dryer.
thanks,
old bones
souNdguy
10-21-2006 22:02:04
 Re: pto jackshaft in reply to old bones, 10-21-2006 16:06:36
TSC has an assortment of smooth / keyed shaft yokes.
Soundguy
Gerald J.
10-21-2006 17:53:49
Baum Hydraulics (www.baumhydraulics.com) has splined stub shafts for just such projects.
Gerald J.
old
10-21-2006 17:29:24
A good farm/home suppy place should have all you need, that is if you can weld. They make adaptors to do almost any thing like that. BTDT more then once and I do a lot of fab work that most say can not be done.
