Found this after a Google Search: How to Repair a Zipper when the Slider Has Come Off Completely For some reason, the slider often comes off old or cheap zippers and there's no way to get it back on. The first method won't damage the fabric but may damage the zipper; the second method saves the zipper at the expense of the fabric. Steps Method 1 Line up the two sides of the zipper as best you can. It is easiest to do this on a flat surface. Ease the teeth from the unattached side into the slider as far as you can get them. Using pliers from above (so that the inside surfaces of the pliers would touch the outside sides of the slider), ease the unattached side into the slider. The unattached side should now be most of the way into the slider. Slide the slider up and down to see if the zipper will fully re-attach on its own. If it does not, then slide the zipper as close to the end as possible. You want to choose the end where you would begin the closing zip. Orient the pliers so that the inside surfaces would touch the top and bottom of the slider. Ease the pliers down until the unattached side snaps back into place. You may need to alternate the use of the pliers from the sides and from the top until the unattached side is fully reattached. When finished, you will not be able to unzip any further than the point at which you forced the unattached side back into the slider as you will have warped several of the teeth on the attached side. Method 2 Look at your broken zipper. One side still has the slider, the other one doesn't. There is an "up" direction (you move the zipper this way to close), and a "down" direction. With a good pair of scissors, make a cut on the side of the zipper that doesn't have the slider, at the same height as the bottom of the slider when it's at it's lowest possible position. Make the cut between two of the teeth of the zipper. Feed the free side of the zipper into the top end of the slider where you made the cut. Slide the slider all the way to the top, until you can't move it anymore. The side with the cut might have a little slack. If it does... Pull the sides of the zipper apart so you have to loose strands below the slider. Pull the side of the zipper where you made the cut down so that the slack on top of the slides disappears. You might have to pull hard. Put adhisive over the cut, and on the zipper below the cut so it's held together. You won't be able to pull the slides farther down from that point. Tips You might severely harm your zipper when you pull it through to avoid the slack. You can also make the cut (on step 2) level with the top of the slider, so you minimize the slack. Warnings Method 1 Using pliers may damage the slider beyond repair. Using pliers to force the unattached side back into the slider will damage the teeth on the attached side. You will be unable to unzip beyond the point of re-attachment. Method 2 Only do this if you won't rip the fabric. If it's valuable enough that you don't want to risk it, consider changing the zipper. This won't work on zippers that should pull apart all the way, like in jackets. Then again, the slider IS supposed to come completely off for those, so you wouldn't have to read this article... Things You'll Need A broken zipper Method 1 Pliers Method 2 Good scissors, or wire-cutters and scissors Strong adhesive for fabric
