Campbell Hausfeld welders
kev
03-25-2001 18:02:21
Im looking to buy a MIG welder and I seen a CH welder at Lowes for $309 Its Model WG3000. Are these welders pretty good..
walt
03-26-2001 17:15:23
 Re: Campbell Hausfeld welders in reply to kev, 03-25-2001 18:02:21
Save yourself the grief. Go with one of the big three..Hobart, lincoln, miller..
J. Vodehnal
06-20-2002 06:08:19
 Re: Re: Campbell Hausfeld welders in reply to walt, 03-26-2001 17:15:23
Just curious as to what faults you found with the Campbell welder. Unfortunately, I bought one before I found your warning on this site. So far however mine seems to be working okay.
kev
03-26-2001 12:42:43
I will be welding thin materials such as auto panals..So I really dont want a mig welder with real high heat settings, I can use my arc for those materials.
Rod Mi
03-26-2001 22:40:24
 Re: Re: Campbell Hausfeld welders in reply to kev, 03-26-2001 12:42:43
I think you still will wont sum thing in the 175amp range you mite wont to ask T_Bone he is the man to ask he will post shortly I�m shire
Rod Mi
03-26-2001 09:44:36
Kev check out this link
http://www.ytmag.com//toolt/messages/16899.html
Rod Mi
03-26-2001 09:41:51
Kev you mite wont to do a search for mig welder on this sight not many people have had good luck with any of the welders under $700.00 they don�t seam to have enough heat to weld anything I have a century 100amp mig and it suppose to weld up to � inch in a single pass but it wont weld 16gage steal with out pre heating you mite wont to look for something in the 200 to 250 amp range and its going to cost you a lot of money and you mite wont to think about renting a welder to see if a particular one will work for your kneads I�m not trying to deter you from the welder you are talking about but I�m just wont you to now the problems most are having with the smaller welders at work they weld a lot of sheet metal and they are welding at about 150 to 200 amps with miller welders there will be more post about your questing and you will get sum very good answers
