Tool Talk Discussion Forum
alternator-bad boy
mark from the f
10-15-2006 07:08:47
I found the source of my battery drain. It is the alternator. Now, are these repairable or do I have purchase a new one? Many posts point to a bad diode. Anybody have any tips? Thank to all who walked me through it. Mark
MarkB_MI
10-15-2006 19:21:24
 Re: alternator-bad boy in reply to mark from the fort, 10-15-2006 07:08:47
I used to always rebuild my own alternators. Not so much to save money, but because my experience with rebuilt alternators is that most are GARBAGE.
However, the late-model GM alternators are a bear to work on (as Bob described), so I had to go back to rebuilts. My luck has been about 50-50: half the alternators seem to last, the other half crap out within a year due to poor workmanship.
You probably won't be able to get parts for your alternator, anyway, unless you go to a small alternator shop that is willing to sell parts to an individual. At that point, you might as well drop the alternator off and let them do the work; we'll be real sorry when there are no more mom-and-pop shops.
Lloyd Llama
10-15-2006 18:25:33
Had a Ford alternator rebuilt once at a local rebuilder - new brushes, bearings, electronics, the works. First thing you know, I was getting calls from the wife at work - "come & get me the battery is dead." After a lot of sluthing, I found that if the car was shut down, and then a door was opened, the draw from the courtesy lamps would kick on the alternator, and it would discharge thru the field coil of the alternator. Bad regulator module - went thru several before I finally went thru the rebuilder's junk pail, and found the origional one. Put it back, and no more problems.
old
10-15-2006 12:21:00
My self I have found that by the time you pay for the parts to fix it your at or around $20-25 and you can buy a rebuilt one for around $30 so to me its not worth doing it my self. Shoot the ones I buy even have a life time warrenty on them so I always just go to O'reillys and buy one and then when it stops working I get another one for free
Bob
10-15-2006 09:17:54
Your 'burb has a CS-130 or similar Delco.
It probably IS repairable, but unless you have a local "mom and pop" automotive electrical shop that has reasonable prices, you'll probably pay about as much as a rebuilt would cost, 'cause they are an expensive alternator to repair.
To separate the stator from the rectifier bridge, to even get the alternator apart, you have to cut the wires loose, as they are TIG welded together from the factory.
If it IS the rectifier (as opposed to the voltage regulator) that's bad, the new rectifier will have solder tabs where the old connections were welded.
If it turns out to be the regulator, the rectifier can be reused, as the rebuild shop will have 3 little adapters that allow the stator leads to be soldered back to the rectifier they were cut free of.
The drive-end ball bearing is crimped in place, in the aluminum endbell, but can be pressed out, and the rebuilder will have a steel clip gadget that he will install to retain the new bearing.
So, it's a little more time-consuming, and more technical to repair these than the older alternators. Get a repair estimate vs. a re-man!
J Schwiebert
10-15-2006 08:47:04
You did not say what kind of alternator you have, but if it is some form of Delco and you have a good Ohmeter you could do it yourself.
Gerald J.
10-15-2006 08:38:50
Repairable. I take mine to a local auto electric shop.
Gerald J.
