Tool Talk Discussion Forum
Homelight Super XL has no spark
Wardner
10-13-2006 08:04:32
Where do I start? Do I take off the starter housing? Am I likely to need parts?
I haven't used this saw in about 8 years. It ran when I parked it in a dry place.
williamf
10-15-2006 06:17:16
 Re: Homelight Super XL has no spark in reply to Wardner, 10-13-2006 08:04:32
I've had a Super XL for well over twenty years. I've had to replace the "ignition module" twice. But the points and condenser would cost a lot less.
ebbsspeed
10-13-2006 08:56:45
Chances are you've got some corrosion on the points after sitting that long. You'll need to take off the starter housing and then the flywheel. Points will be under the flywheel.
