Tool Talk Discussion Forum
Source for lovejoy coupling inserts?
Brian in NY
10-10-2006 06:38:44
Northern Tool is backordered until the end of the month for standard duty inserts.
Any place else that has them available now?
Need one for log splitter.
Thanks!
Bob
10-10-2006 21:52:33
 Re: Source for lovejoy coupling inserts? in reply to Brian in NY, 10-10-2006 06:38:44
ANY local "bearings and drives-type" industrial supply house would certainly have them.
in sticks
10-10-2006 18:46:47
can you make them from the,not sure of termnolligy here,white plastic material that's the right thickness,using a hole saw for circle then bandsaw for cutouts?
Jim K
10-11-2006 18:05:28
 Re: Source for lovejoy coupling inserts? in reply to in sticks, 10-10-2006 18:46:47
Hey! I like the nylon idea or even a thick truck tire might work in a pinch.
Gerald J.
10-10-2006 11:21:53
Baum Hydraulics>Link
McMaster-Carr>Link href=" Link
Gerald>Link J.
Pooh Bear
10-10-2006 10:35:53
I just got a whole coupling from TSC. All 3 parts.
And each part is compatable with an actual
LoveJoy coupling that I have on hand.
I checked cause I was curious.
Pooh Bear
Brian in NY
10-10-2006 10:41:57
 Re: Source for lovejoy coupling inserts? in reply to Pooh Bear, 10-10-2006 10:35:53
TSC= Tractor Supply Co., correct?
Pooh Bear
10-10-2006 19:42:21
 Re: Source for lovejoy coupling inserts? in reply to Brian in NY, 10-10-2006 10:41:57
Correct.
Pooh Bear
Aleuicius
10-10-2006 08:46:32
Found that the "spider" inserts carried by Tractor Supply are the same. Good thing, too - it doesn't take much mis-alignment to chew them up.
Glen in TX
10-10-2006 08:32:48
grainger.com or any industrial bearing supply place local.
souNdguy
10-10-2006 07:15:19
TSC has them.
Soundguy
1945 A
10-10-2006 06:45:17
Any decent bearing supply place should have them.
The coupling will have a size stamped on it like "075" or whatever. Given the size, they can supply you with the insert.\
Good Luck!
GREENWORM
10-10-2006 06:44:33
try Granger Supply I get mine there
