Tool Talk Discussion Forum
Tig Weld cast metal?
hayray
10-10-2006 04:57:30
My alternator bracket on my 2-105 cracked so I need to weld it. How do I tell if it is cast iron or just cast steel? or are they the same? Welding cast I have had problems getting a good non-porous weld. I have some nickel rod and I have tried grooving out the crack and then lay ing the nickel rod into the groove and running the torch over the top of it. Any ideas on the best way to tig weld this?
Ray
hayray
10-11-2006 04:33:46
 Re: Tig Weld cast metal? in reply to hayray, 10-10-2006 04:57:30
Thanks guys, great info. If I have any more problems I will let you kjnow.
Don L C
10-12-2006 17:19:27
 Re: Tig Weld cast metal? in reply to hayray, 10-11-2006 04:33:46
Gas tourch & brass rod w/ flux..... .
First grind a grove around the break..... Don
george md
10-10-2006 15:19:26
third party image
Ray , If it is cast iron , do as Glen says get some bare cast iron rod and a can of flux. Grind it to a good vee , preheat to at least 900 deg F ,
weld with torch , post heat 1200 unless you have
to drill and tap a hole . if so post heat to 1500
and hold for 15 minutes to normalize , cool very
slowly .
Brazing should be your second choice of repair,
and arc weld a very distant third choice. Arc is
never strong on cast iron due to the internal
stresses created when cooling , you CAN NOT get
away from them because the nickel contracts at
a much greater rate than cast iron . The cast is
not ductile and can not move to follow the shrinking nickel weld , that is what makes it
crack when cooling.
Tucker valve seat inc in odessa tx has the rod, I usually buy 50 pounds at a time .Also harris-
welco has the rod and flux .
I'm one of the fools that likes cast iron repair
and I do quite a lot of it .
george
Shawnspeed3
10-10-2006 09:17:01
Ray, you can use hi nickel rod and your tig to repair that bracket ,a little pre/post heat will help,and you may have to weld /grind once or twice to "float " out any impureities in the are surrounding the weld.Also be sure to taper out of the weld puddle ,and not stop the arc abruptly, as this will cause an inclusion,and crack. If it is cast Iron , I do short sections,peening in between to stress relive. You could also use silicon bronze, a very good altenative because you only heat the base metal to a dull red heat( leaves impurities in base metal) when the bronze will wick nicely.do not use regular brazing rod, it is not the same . I can get you the crown alloy number when I get home , don't have the reference book at work...Shawn
Glen in TX
10-10-2006 08:37:01
Go get some of that square looking cast rod if you find out you actually have cast iron from the test posted below. The square rod is actually cast iron and can be used with heli arc or torch. Might have to go to a welding shop to just buy a stick or 2 as that's the problem around here the welding supply doesn't stock it and you have to buy so much of it on a minimum order deal.
varmint
10-10-2006 05:42:25
touch the part to a grinder if the sparks are short &red it will be cast iron, long and bright with tails is steel. grinding for grooves leaves stuff from the stone in the weld an makes it porous so use a steel or Carbide cutter in the groove
