Cast Aluminum Repair? Filling a hole the size of a quarter
tom
03-24-2001 11:58:47
I am restoring a 1940 Cast Alumiunm Ford 9N Dash...
I do not want to paint the dash section but polish it. And of course, there is a cobbed hole about the size and larger of a quarter just left of the ammeter gauge that does not belong for that year and model of dash. It was hand drilled, the perimter looks as if a chisel was used to enlarge it, and a small diameter round file was then used to enlarge the interior of it. It's not a very good hole to say the least.
Can it be filled? and then ground and polished to match the surrounding dash? and/or will there be a noticeable patch? What is the recommended technique, process and material to best fill it?
Other options? thank you in advance. tom
greg
03-24-2001 14:13:23
 Re: Cast Aluminum Repair? Filling a hole the size of a quarter in reply to tom, 03-24-2001 11:58:47
Tom-
either you are 9N'er, or you have a twin over at the 9-2-8N site.
I would say paint what you got, plug the hole with the lever, and use it until you find another one. Y ou could always get rid of it on ebay (probably for twice what you paid) and you could still use the tractor until you find a new one.
If you decide to do this, don't try to fill the hole. It might just make it worse, and you could leave the experimentation to the next guy.
Just my nickles worth!
Greg
