Tool Talk Discussion Forum
JT
Bob Underwood
10-03-2006 14:00:21
This model, what I am calling the coil fits over the sparkplug. There is no wire to the plug.
Bob
JT
10-04-2006 12:44:44
 Re: JT in reply to Bob Underwood, 10-03-2006 14:00:21
teej you are right, Homelite made a 360, not Stihl, I was thinking of the MS360 when he said it was a 360,and if it is a Homelite, there is no way to check the coil on it. If it does not run, check compression, these need a minimum of 100psi to run.if it has compression of at least 100psi, and you like the saw, just buy the aprts and replace them if they are still available.
teej
10-05-2006 07:49:29
 Re: JT in reply to JT, 10-04-2006 12:44:44
I did come up with a way to test them. using 2 jumper leads to connect the plug boot to its terminals on the coil, and then a spark tester that had the flashing bulb in it. Couldn't tell what kind of spark, but you could determine if it had one or not.
Regardless, it was a pain in the butt to do.
teej
10-03-2006 23:54:28
Don't think there is a Stihl 360. Its either an 036 or an MS360. If its not those, you have a Homelite 360, which is a big red saw, mostly metal. Stihl has a lot of plastic cases and housings and are orange and white. Homelite is completely red.
I've never worked on a Stihl that had the setup you describe, but Homelite does.
There is a coil near the flywheel, under it I think, that "boot" you have connects by 2 terminals when you screw it on over the sparkplug. These are a pain to test, but can be done if you connect the small terminals with jumper leads, then use a spark tester in the boot.
This saw is old enough to have points as well as a coil. They are also under the flywheel if I remember correctly.
