Tool Talk Discussion Forum
Craftsman drill press pulley
Paul Janke
09-30-2006 17:48:47
My drill press is a Craftsman model number 103.23640. The pulley on it broke. The side of the largest diameter groove (the lowest speed) split away from the flat at the bottom of the groove. It has the number 22416-103 cast in it. Sears no longer lists parts for it. Now what? You guys will have an answer if anybody does. Thanks in advance.
fzbcheve
10-01-2006 17:53:33
 Re: Craftsman drill press pulley in reply to Paul Janke, 09-30-2006 17:48:47
If you can't locate a pulley, you can cut the hub out of the old pulley and put it into a new pulley of the same size. Cut the old hub down to size, and bore the new pulley to a slip fit, Put them together with loctite 608 or 609. Thats the green stuff. It has a sheer strenght of 4000 psi.
Charles (in GA)
10-01-2006 12:56:12
Link
I never imagined that Sarlo made drill presses!
I have an old Sarlo mower. Didn't know what it was, the data plate was on the belt guard which was missing. A local mower shop ID'ed it and called Sarlo when I needed parts. Even though it was quite old, they had the parts, reasonable price too.
Charles
you
09-30-2006 19:27:50
Paul,mcmasters,or graingers might have something.And i believe that ive seen step pulleys in a good hardware store someplace.worst to worst a machine shop should be able to turn one for a reasonable price.good luck
fzbcheve
09-30-2006 18:47:45
The number 103, means that unit was build by Sarlo Power Mower Inc.
Check the internet and see what you can find.
