Tool Talk Discussion Forum
V4HD Wisconsin
Paulv92
09-30-2006 12:30:27
I have a 630 Bobcat with a V4HD wisconsin. It died the other day & wont start, I have fire, fuel and spark. I put a new coil on because fire looked week,no good, had new plugs a few weeks earlier, points have good spark, spark at the coil, & plugs. All it will do is backfire through the carb. Even give it a shot of ether & just backfires Please give any input.
Glen in TX
10-01-2006 15:21:54
 Re: V4HD Wisconsin in reply to Paulv92, 09-30-2006 12:30:27
Yeah check compression on all cylinders. I had one of those V4s snap the camshaft and two cylinders had no compression. Hope it's not that but what happened to me on one on a generator. If good compression and fire then is it getting enough fuel to carb? Bad fuel pump?
RN
09-30-2006 12:58:29
Check your valves- backfire is known symptom of no lash, burnt valve, worn seats. Compression test to check for bad cylinders. Ignition timing is OK? RN
paulv92
10-01-2006 07:29:41
 Re: V4HD Wisconsin in reply to RN, 09-30-2006 12:58:29
Best I can tell the timimg is ok! I rolled the engine over to the timing mark on the flywheel and the rotor points to number 1cyl. I need to run a comp. check I removed the spark plugs, held my finger over the hole & cranked it seemed ok. I know this is not good methods but the Bobcat is at my house & my shop is ten miles away, I think I will go get my timing lt. & comp. checker though. Any other suggestions please let me know. Thanks Paul
