Tool Talk Discussion Forum
balancing bush hog blades
wcroom
09-28-2006 18:53:31
What is the proper way to balance blades on a bush hog? I know how to do it on a regular mower blade, but not this. My bush hog has developed a vibration when it spins. The blades don't look damaged. Looking underneath and spinning the blade carrier by hand, the shaft doesn't look bent. I can watch the space between the carrier and the deck and that space stays constant as I turn the blades. Do I remove the blades and balance them one against the other and sharpen until they hang equal( the nuts on the blade bolts are tacked in place)? Do I remove the whole stump jumper and hang it on a pin in the center hole and balance it that way? Can I just stand the bush hog on end and see which blade hangs lower? I know this is a stupid question, I just don't want to screw it up. Thanks, Wesley
wcroom
09-30-2006 16:13:38
 Re: balancing bush hog blades in reply to wcroom, 09-28-2006 18:53:31
So here's what I did: I marked a spot on the stump jumper with some orange marking paint. I spun the bush hog, then disengaged it and watched the blades wind down. With the mark, I could note which blade was pulling or causing the shake. I sharpened that blade and tried it again. No vibration. I sharpened the other blade and the vibration came back. Took a little more off of blade #1, and the vibration dissappeared again.It really didn't take much grinding to make a big difference in the balance! The lighter blade had a small nick in the leading edge. That, apparently, was what threw it off in the first place.I guess it makes sense, something spinning that much metal at 540 RPM develops some serious centrifugal force. Thanks for the help, guys ! Wesley
Sand Flat Bob
09-29-2006 11:07:49
Just a thought on what I have experienced. Are you sure that the blades aren't binding on the stump jumper pivot bolt. I have had this happen and after hitting a fire ant hill etc. the blades don't come back straight out from the stump jumper, and it will really shake.
If they are loose on the pivot, then I would put on new blades.
Bob
Sand Flat Bob
09-29-2006 11:04:27
Bob
ebbsspeed
09-29-2006 08:28:13
Ideally they should be balanced a lot like connecting rods, support one end and weigh the other, then flip it around and do the same the other way. Make the cutting ends of each blade weigh the same, and the pivoting ends of each blade weigh the same and you'll have a smooth running unit. You do this because the ends of the blades spin in different diameter circles, so simply making the blades weigh the same WITHOUT making them weigh the same end for end will still result in a vibration.
jeffcat
09-28-2006 23:10:26
Not a stupid question cause you are dealing with a very mean unit. The bolts are welded to CYA the company. IF you grind off the little weld you should use big case eight bolts with stop nuts and maybe still tack em at replace time. Now to the blades. I would go to your local Tractor Supply or such and just by new ones. The price is cheep enough!
Orrr..after you get the blades off you need to make then both as close to the same as possible. With you hand grinder you want to put on a nice edge and make sure they are the same long and wide. Now you take them and weigh them on a GOOD spring scale or a digital type used for air conditioner work. I bet if you weigh them right off of the machine you will be shocked at how far off they can be. Just remember that one quarter pound off will really rattle your teeth with these machines. You are looking at a lot of work when a nice drive to town will do the trick. I would still take a blade with you for a sample and buy new.
Let us know. Jeffcat
jddriver
09-30-2006 10:20:38
 Re: balancing bush hog blades in reply to jeffcat, 09-28-2006 23:10:26
JC not to dispute you but the tsc blades that Ihave gotten suck they do not clean out under the deck and only weigh about half as much as oem Steve
