Micrometer
Valerie
03-23-2001 07:08:13
How is a micrometer used/read? TIA!
john d
03-23-2001 20:06:36
 Re: micrometer in reply to Valerie, 03-23-2001 07:08:13
F14's link is a very good one! Also...measure things that have been wiped clean, keep the measuring surfaces of the micrometer clean, DO NOT clamp the micrometer tightly onto the object you're measuring. It's not a C-Clamp; it should fit snugly, but you should be able to slide it on and off the object being measured.
It seems like common sense would indicate that the next point wouldn't need to be mentioned.... but after years of dealing with jhs kids, I will: NEVER attempt to measure a moving or rotating object!
Valerie
03-24-2001 15:39:48
 Re: Re: micrometer in reply to john d, 03-23-2001 20:06:36
Thanks--I appreciate the advice!
F14...Here's a beginning...
03-23-2001 07:25:27
Scope out the link below. Gives a pretty good primer on how to read a mike.
Valerie
03-23-2001 07:36:28
 Re: Re: micrometer in reply to F14...Here's a beginning..., 03-23-2001 07:25:27
Thank you for your quick response!
