Tool Talk Discussion Forum
Tool Opinions Wanted Jump Start Battery Pack
Pooh Bear
09-26-2006 00:26:08
I was in Harbor Frieght today picking up some castor wheels.
I had a 20% off coupon for any single item.
I needed one of these so I bought it.
3 in 1 Jump Start Air Compressor 12volt power supply.
$49.99 with 20% off. Good deal or not.
I don't need it as a jump starter.
But I like the air compressor and power supply.
And the built in light could come in handy.
My only concern is it is a Harbor Frieght brand.
So what do ya'll think. Good deal or not.
Thanks.
Pooh Bear
Pooh Bear
09-26-2006 15:09:35
 Re: Tool Opinions Wanted Jump Start Battery Pack in reply to Pooh Bear, 09-26-2006 00:26:08
Thanks for the opinions.
I have no plans to use it as a jump starter.
I just like to have a 12volt power source around.
I have been borrowing one and plugging my little
12volt compressor into it. Or sometimes a light.
Hooked an inverter to it once to run a computer.
I need it for stuff like that. Not jumpstarting.
Mostly wondering about the battery life of the unit.
How well does it hold up.
So far it seems to do great.
Thanks.
Pooh Bear
Davis In SC
09-26-2006 19:50:39
 Re: Tool Opinions Wanted Jump Start Battery Pack in reply to Pooh Bear, 09-26-2006 15:09:35
I have one from Home Depot, Husky is the brand.. It is just the jump unit, no compressor. I use it to start the tractor & skid steer, if they have been sitting & the battery is just low. It actually started a MF 245 with a totally dead battery, the battery would not even take a charge.. The unit also has a light built in, LED's. I left the light on all night during a power outage, & the next morning, the unit still showed a full charge...
KEH
09-26-2006 07:30:47
Got one from Sears. It won't start a completly dead battery(left switch on in tractor, had to take battery out and charge it). It also has a 110 volt outlet and it is great for running an electric drill, which has a lot more power than a 14.4 cordless. Good for working on corral in remote location. Haven't tried air comprssor. Also has large light and a radio.
KEH
souNdguy
09-26-2006 06:53:43
For heavy loads like a big diesel.. I'd use it as a 'booster'.. but doubt it would jump from dead.
However a weak battery.. or cold battery.. it may be just enough to get her going.
Soundguy
Red Dave
09-26-2006 05:59:42
I have one exactly like that. Works great starting small cars & lawn tractors. Compressor works OK, but has a very low volume so it takes quite a while to fill a tire from zero. Tops off a tire OK though.
Doesn't work very good starting larger vehicles that have higher amp draw.
NTP
09-26-2006 05:57:41
These units work very well for jump starting your tractor or lawn tractor if needed. I also have used it for starting my boats when I left them in the water with too little use to keep the battery up. However, as mentioned, don't use the compressor any more than necassary, or when you do need it, it won't work. They have a very simple and cheaply built compressor,
bradk
09-26-2006 05:24:45
Pooh,
I know a couple guys that have a similar multi-pack.The compressor works about three times,but the rest seems OK for lighter use.~brad
