Tool Talk Discussion Forum
Well....
nballen
09-25-2006 09:21:27
Usually, I just lurk here and enjoy the humor and the learning, but I'm going to take exception to something you wrote here:
"Heavy metal equals heavy stress. If it didn't, everything would be made from the same size and strength material."
Actually, heavy metal (I think you mean 'more metal', not denser metal) is used for heavier _loads_ or forces. Ideally, the sress (force per unit area, psi or lbs/sq in) would be very similar (working stresses somewhere between 2,000 psi and 30,000 psi, depending on the strength and application of the particular material.
A designer or engineer can reduce the stress in a particular component by a) reducing the forces applied, b) increasing the strength (allowable stress), or c) increasing the cross-section that carries the load.
All the best,
Nathaniel
