Tool Talk Discussion Forum
Truck box floor
Mike in Ne
09-24-2006 14:30:19
Has anyone replaced the wooden floor of a grain truck box? What kind of wood is best to use, or should I just cover it with steel? Thanks.
iowa_tire_guy
09-25-2006 19:25:36
 Re: Truck box floor in reply to Mike in Ne, 09-24-2006 14:30:19
25 years ago my Dad and I replaced the floor in his grain truck. We used tongue and groove pine and the special nails from the factory. The boards were treated with linseed oil before we installed them and we painted porch and deck enamel on the top after we put it in. Dad still has his and the floor is just now begining to need repairs even though it sits outside much of the time. The key is to keep it painted and I am sure the linsed oil didn't hurt. My experience with treated lumber would be to stay away because it is not dry yet when the sell it.
Gerald J.
09-26-2006 07:26:56
 Re: Truck box floor in reply to iowa_tire_guy, 09-25-2006 19:25:36
Ordinary treated lumber was once dry but hasn't been dried after the pressure treatment. That's the nice feature of foundation grade, it not only has more stuff, its been kiln dried again so it doesn't shrink like it was just sawn from the green log.
The stuff I made a trailer deck from hasn't shrunk any in three years.
Gerald J.
nballen
09-25-2006 09:30:01
There's a reason so many grain trucks have a steel box ;->
If you're using this for "only" hauling grain, I would guess steel is 'bout the only way to go. If you are using this truck for other hauling, you may want to stick with wood... I like the wood floor for general hauling (the _very_ little I've done), since it's not as slick.
But that's just my opinion.
Nathaniel
Gerald J.
09-24-2006 15:18:08
I tried 2x6 tongue and groove CCA treated lumber. I slid the last piece in with a chain hoist. In a week the boards shrunk enough I slide that one out and put in another a half inch wider. In a year or two I could have added nearly half an inch per plank.
Since then I built a flat bed trailer and for the floor I used treated 2x6 and 2x8 for the floor planks. This lumber is foundation grade, kiln dried after treatment. Its HEAVY, but there are no cracks from shrinkage after three years, part of that time out in the weather.
Gerald J.
