Tool Talk Discussion Forum
Weed Blocker
Steve-Maine
09-24-2006 08:27:17
I have a chance to get a large roll of material that is used between subsoil and gravel fill for a drive so that clay won't work up throught the gravel. Could this be used as a weed blocker under bark mulch in a planting bed? Water will go throught it. Its a lot heavier than regular weed blocker. Thanks
ohkentucky
09-25-2006 08:37:54
 Re: Weed Blocker in reply to Steve-Maine, 09-24-2006 08:27:17
Ive used regular weed blocker and hated the stuff. Its expensive,and once down you cant do anything to the soil or plant any additional plants,then in a year or two weed seeds that fall into the mulch and germinate and then youve got a worse problem than you started with. One thing it does do is hold moisture good, you dont have to water nearly as often. I took mine up after about 4 years and thru it away. It was not easy to get up. I would just rather use pre-emergent herbicide. Its not any more expensive than the fabric and you can always dig when you want to change something.
HDM
09-24-2006 08:29:49
I use many rolls a year for just that purpose. The rolls used to be 12.5' x 435' but now they are 15' wide. Good stuff.
Steve-Maine
09-24-2006 12:12:28
 Re: Weed Blocker in reply to HDM, 09-24-2006 08:29:49
Thanks, I'll go up to my son -in law and pick up a full roll for nothing. thanks
