Tool Talk Discussion Forum
aircompressor for shop
mpuller2
09-24-2006 08:24:05
Looking to buy an aircompressor for shop. Questions---
What size do I need? Major use is to air up tires,small air tools and blow gun.
My shop is 80'X 60' Can I run copper pipe from one end to other for permanent air lines?
What else do I need to know? Thanks.
jpuleo
09-26-2006 23:29:08
 Re: aircompressor for shop in reply to mpuller2, 09-24-2006 08:24:05
Bigger is better. I was offered a older 200gal HUGE 3stage unit for $100, but it was too big to fit in the truck. I know some of the guys here would have loved it.
I get by fine with a 30gal roll around unit. Runs inpact guns, paint guns and blow guns fine. Kind of overworked on sanders, grinders, and sand blasters, but it will get me by in a pinch on those. I like electric sanders better anyway.
To tell you the truth, my 3gal will run the impact, ratchets, and air guns fine for hobby use. Kind of works for the paint gun and air chisel, but not great.
Don c
09-25-2006 07:40:05
Don"t run plastic lines on air compressors, to many horror stories on the plastic blowing up and hurting people, its like scrappnel when it come apart. TIPs in Canfield Ohio can offer the best advise on piping, all metal pipe is the only way to go.
john_bud
09-25-2006 06:45:35
Air compressor size is like shop size, can't be too large (only too large to heat!).
One of the 240v 6-7 hp units with a 60 gal tank giving 10-12 cfm at 125psi is a decent starter. They go for $350-450. Now with that said, a GOOD unit will have a 5-7 HP motor that runs at 1750 rpms and a two stage compressor giving 15-18 cfm at 175 psi. It will have the same or smaller motor, but will be physically much larger. Cost for a good one is $1200.
If you are ever going to sand blast, paint or do other high air draw chores, the big one will perform better and last longer while running quieter and cooler.
With the cost of copper and iron so high, have you looked into running plastic lines? There are ones made specifically for compressed air. Only use that.
Bernoulli/OR
09-25-2006 06:36:06
I agree with Charles. Bigger is better. 220VAC and two-stage is also better. Forget HP ratings and look at Amps and CFM/PSI output ratings.
Charles (in GA)
09-24-2006 14:57:29
Bigger IS Better. You will always be thinking of more uses for your compressor, usually taxing its capacity. As noted, for what you describe, a decent portable will suffice, but as soon as you get it, you will be toting a blast cabinet home from Harbor Freight and a host of other tools and items that are high draw, and wishing you had a bigger compressor.
Let your wallet be your guide.
Charles
Tim Casbolt
09-24-2006 11:03:47
For the things you mention, a small portable air compressor would be fine. If you think you might ever want to run bigger air tools, a d/a sander, or a blast cabinet, go the extra money now for a 60-80 gallon tank and a 5-6 hp motor. Home Depot and others sell one like this for about $300. I bought black pipe at Home Depot and a threading kit from Harbor Freight and ran my air plumbing along the underside of the trusses with T's for drops about every 10 feet. Put a drip leg down low and angle everything toward it so it's easy to drain the water out.
george md
09-24-2006 20:49:35
 Re: aircompressor for shop in reply to Tim Casbolt, 09-24-2006 11:03:47
Tim,
I was in your territory today , went to the
cecil county farm museum ( Dave Reeds ).
george
Areo
09-24-2006 16:09:22
Right on Tim!
No couplings. Every joint has a tee. I angle my tees up at 45 degrees and put in a reducer to 1/4 or 3/8 (line size) and put in a street ell and a plug in that. When I need the drop, just remove the plug and add the hose. Did this in three shops I worked at.
HTH
Areo
Steve-Maine
09-24-2006 08:29:41
I used copper pipe a few years ago and worked fine. A lot easier to put together than black iron. Although price of copper is quite high now. If you can find a TIP Industries catalog they show how to run the drop lines. Good Luck
