Tool Talk Discussion Forum
Oil for Air Compressor
Archie Williams
09-23-2006 14:30:47
I had posted this earlier but I don't see it showing up.So I'm trying again. I have an OLD air compressor the only name I can find on it is SUNROC. The compressor got turned over in my truck and all the oil has leaked out of both cylinders. What type of oil do I refill it with and how much? I can send pics if anyone would need to look at it. PLEASE HELP! Thanks in advance!
CompressorProfessor
10-02-2006 21:42:32
 Re: Oil for Air Compressor in reply to Archie Williams, 09-23-2006 14:30:47
With any air compressor, it is important to use an oil specifically designed to handle the heat of compression of an air compressor. Call a local compressor repair center- if you use standard motor oil, the high heat will cause premature failure.
IA Roy
09-26-2006 20:36:20
I am using a synthetic motor oil. My wiring to the building is a little light and the synthetic turns over a little easier when cold. The fuse doesn't blow as often now. It is a "Rated 5hp" Sanborn. Talk to the guy at Napa like I did and see what other people are using.
Archie Williams
09-23-2006 18:43:40
How much oil do I add? It looks like the cylinders have a "sump" in the bottom. Should I just fill that? Or fill up to the fill-hole?
Charles (in GA)
09-23-2006 18:38:23
You are getting alot of varied suggestions, but actually all are correct. Home Depot or Tractor Supply will have Ingersoll-Rand compressor oil, and it is certainly suitable for almost any oil filled portable compressor, my old Craftsman iron pump portable called for 30 wt non-degertent oil, I ran it for years on Mobil I and it worked fine. My three year old Husky (Cambell-Hausfeld) iron pump stationary compressor called for 5w-30 Mobil I for warranty. Take your pick.
Charles
BigMarv1085
09-23-2006 17:15:09
I bought some air compressor oil from tractor supply, it's over by the air compressors.
Don L C
09-23-2006 17:05:28
I put 10w 30w in mine 30 yrs ago....have checked it but not changed it , runs fine....
Don c
09-23-2006 15:11:31
Go to some place that handles air compressors and get the regular air compressor oil, it different then regular oil.
Joe in MN
09-23-2006 14:48:44
Non-Detergent 20 weight
