Tool Talk Discussion Forum
Yo,Roger/air compressors
JoeK(WI)
09-23-2006 13:48:41
Putting together the bits for a spare portable compressor.Have a clean/tested 20gal tank,w/reciever,check and popoff valves.Have an older Sanborn no.84 2cyl pump(hex valve caps) in good shape.Questions are,1-proper hp range and RPM for this pump,and 2-1725 or 3450 rpm motor best for job or"no matter" as long as pump speed is within specs.Pump has 10" flywheel.
Thanks in adv/
XRogerX
09-25-2006 21:01:30
 Re: Yo,Roger/air compressors in reply to JoeK(WI), 09-23-2006 13:48:41
I know nothing about this pump, but a wild guess tells me it might be about 1-2 hp. If it is single stage (both cylinders pump from atmosphere to full pressure) you can figure out the displacement in cubic inches, then divide by ten. This will give you the required hp for the pump.
I'd wager this pump would run between 800 to 1000 rpm. I'd go with the 1725 rpm motor, since you can run a larger pulley on it, which will give you a longer arc of engagement on the belt, which will improve belt slip resistance and belt life. About 130psi is the practical limit for a single stage compressor. If you find that you are not anywhere near max amp draw at that cutout pressure, you can increase the pump rpm to improve output, as long as you keep the rpm reasonable (approx. 1000rpm max).
JoeK(WI)
09-27-2006 09:57:08
 Re: Yo,Roger/air compressors in reply to XRogerX, 09-25-2006 21:01:30
Thanx,the pump was originally on a Sanborn Portable,that the tank rusted out on.Former owner could not remember motor specs,but thought it was a 1hp,1725rpm.Rig will just be a spare/backup for light duty so "max" output isn't real critical. Thanx again.
