Tool Talk Discussion Forum
Stihl chainsaw not oiling chain
Mike in MI
09-21-2006 17:00:04
My son borrowed my 034 and said the saw wasn"t getting any oil to the chain.
Is there a filter in the reservoir on this saw? Or should I take the saw to a dealer and have them look it over?
Thanks for your help.
Mike
Mike in MI
09-22-2006 11:00:18
 Re: Stihl chainsaw not oiling chain in reply to Mike in MI, 09-21-2006 17:00:04
Like to Thank all of you guys for your comments.
He said the saw wasn"t pump oil to the bar. The trouble must be internally? Know more tomorrow when he brings it over.
Thanks again for your help!
Mike
supergrumpy
09-22-2006 06:35:29
mine did the same, turned edge of the bar blue before I noticed it, dealer cleaned the pump and gave me a well-deserved lecture on cleaning outside of the caps with old paint brush before removing them
if you have to saw today, maybe thin down the bar oil with bit of kerosene, should work for a bit until you get time to work on it
oil filter in the tank has slots, keeps the big chips out of the oiling system but will let fine sawdust thru, real tiny stuff will pump thru but that "in-between" stuff collects inside the pump and restricts the flow
nballen
09-22-2006 07:18:22
 Re: Stihl chainsaw not oiling chain in reply to supergrumpy, 09-22-2006 06:35:29
An old toothbrush works well also. I like the short, stiff bristles for cleaning stuff like that.
wfw
09-22-2006 05:22:41
also you might take a small screwdriver and clean out the slot in the bar that the chain runs in, it gets clogged with chips really easy, anytime i have the bar off i clean this out
Tim B from MA
09-25-2006 09:25:34
 Re: Stihl chainsaw not oiling chain in reply to wfw, 09-22-2006 05:22:41
Break an old hack saw blade in half. The broken ends end up with a slight bend or hook that is perfect for lifting the oily saw dust out of the runner on the bar as you run it up and down the bar.
butchcmo
09-21-2006 17:18:41
dump all the oil out of the resivoir fill it about 1/4 to 1/2 full of chain saw gas put the cap back on and shake well then dump the gas back out this will clean out your oil resivoir also take your bar off and make sure the oiler holes in you bar are not plugged while bar is off clean the saw where the bar bolts on of old oil and saw dust
Sgt Rock
09-21-2006 17:13:59
Yes there is a little filter at the end of the oil pickup tube in the oil tank. Check the filter and the tank to make sure that there is nothing forgein in the tank.
