Tool Talk Discussion Forum
Miller Spot Welder has quit:?
Robert in Md
09-20-2006 16:30:10
I have an old model LMS W52 spot welder that has quit working. Every wire has continuity, cord, switch and coil . When I try to weld the coil hums and clicks but does't get hot. Anyone have any idea whats wrong. I tryed to find a manual on Millers site but it won't come up. Thanks Robert
T_Bone
09-21-2006 17:07:23
 Re: Miller Spot Welder has quit:? in reply to Robert in Md, 09-20-2006 16:30:10
Hi robert,
I'm not for sure as I have never torn a spot welder apart, but the secondary side should be a direct tap off the transformer.
If you have a output heat setting then check on either side of the heat control.
I would see if you have any output on the secondary side and if not then you will probably need to find the short and rewind the coil.
T_Bone
Bill WI
09-20-2006 18:49:05
Did you file the copper contacts flat that contact each side of the metal? Might be over simple, but don't know if you did much with spot welders. Is there enough pressure? Never worked with a Miller, but did repair work on industrial Banners.
