Tool Talk Discussion Forum
Trucks- - -Slow oil pressure buildup on your 325
XRogerX
09-20-2006 16:28:38
Learned something new today. I was visiting my old shop and a 325 was apart on the bench. On the low pressure end of the crankshaft, there was a brass hex nut on the bottom of the counterweight. I never paid much attention to it before, since some have them and some don't. We decided to pull it to figure out exactly what it does, since I thought it was just an oil jet to help feed the LP wristpin and rear taper crank bearing. Turns out, there is a spring loaded brass shuttle inside the counterweight that slides back and forth inside a cast iron bore. When running, oil pressure and centrifugal force thows the shuttle outwards to seal a port, allowing oil pressure to build. When the compressor shuts off, a return spring lifts the shuttle off of the brass seat, allowing the crankshaft to dump oil pressure. This would make sense in order to allow the hydraulic unloader to open, sending air pressure to the head once the compressor was off. If this shuttle gums up, I could see it not seating properly, allowing oil out through the bottom of the counterweight, preventing oil pressure from building up. Something to check.
