Tool Talk Discussion Forum
Need I.D. help on shredder gearbox.
Patrick Martin
09-18-2006 05:41:03
Hey guys, I need some help for a friend. A friend of mine at work has the shredder shown below and the receptacle in his pinion gear stripped out as well as the short communication shaft that the telescoping shaft from his PTO ties into.
I don't know if this is a homemade cutter or not. It looks pretty professional built to me. If you recognize it then please post with the manufacturer.
Does anyone know who makes this gearbox and where I can find parts for it?
Below with the pictures links are links to a picture of the part that I need. The bearings press on but the surface that the larger bearing installs onto has shattered and I will need to replace this whole unit.
Please help if you can!!!!! :-)
This is a front pic with the gearbox and short shaft installed but loose.
These are of the complete shredder.
third party image
Here are links to more. Copy and paste to your address bar to view.
Link
Link
http://img.photobucket.com/albums/v425/EZFEED/MVC-007S-1.jpg
http://img.photobucket.com/albums/v425/EZFEED/MVC-008S-1.jpg
http://img.photobucket.com/albums/v425/EZFEED/MVC-009S-1.jpg
http://img.photobucket.com/albums/v425/EZFEED/MVC-010S-1.jpg
http://img.photobucket.com/albums/v425/EZFEED/MVC-011S-1.jpg
http://img.photobucket.com/albums/v425/EZFEED/MVC-012S.jpg
I'm sure someone here either has one or recognizes the gearbox and knows where I can find parts.
Maybe you know where I can find a replacement gearbox?????
Please help if you can.
Pat
Slowpoke
10-01-2006 00:06:23
 Re: Need I.D. help on shredder gearbox. in reply to Patrick Martin, 09-18-2006 05:41:03
If you have a bad shaft, consider spray welding. It's put in a lathe and material is shot on the shaft and welded to it. Then it's turned to original diameter. I've never had it done, and it's kind of pricey, but if you can't find the part.....
oldart
09-19-2006 18:13:25
it looks like the belt pully gear box that ford tractors use even the flane that the blades bolt on toif the case is ok you may be able to get parts from a new holland dealer
JV
09-20-2006 04:36:36
 Re: Need I.D. help on shredder gearbox. in reply to oldart, 09-19-2006 18:13:25
Same thought occured to me. Shouldn't be hard to get parts if the rest is undamaged. Looks like a pretty good bushhog.
Cheers, JV.
Patrick Martin
10-01-2006 00:45:56
 Re: Need I.D. help on shredder gearbox. in reply to JV, 09-20-2006 04:36:36
I sure will try the new Holland guys. Thanks a lot fellas!!!!! :)
