Tool Talk Discussion Forum
The best way to fill a tractor tire with fluid....
Donald M
09-17-2006 18:24:14
is how? Do I need a pump? What are my options regarding the type fluid? Thanks.
Dave Sherburne NY
09-19-2006 16:23:07
 Re: The best way to fill a tractor tire with fluid in reply to Donald M, 09-17-2006 18:24:14
I just posted the answer on the Oliver board so
its easy to cut and paste it here.
Let me tell you how I did it on a MF 35 this spring.
First you go to www.Gemplers.com and order Item no.
AQF1 Quick fill tractor tire Attachment.$13.95.
Next you get two plastic 55 gallon Barrels with the
caps you can screw a pipe fitting in. In one cap
you put a fitting with a valve in it that you can
screw a garden hose to. In the other,you put a
valve stem like the type found in water tanks for
pressureizing the tank. Then you take your barrels
and go to the local car dealer and ask if he has any
used antifreeze you can haul away for him. He has
to pay to have it hauled away if you don't take it
Usually they wind up with oil floating on top of
the antifreeze. so if he has a pump to pump it
into your barrels, you can stop before you get any
oil. It takes about two barrels for 12.4x28 tires
Then you take it home, and leave it right on the
truck. Jack up one wheel of the tractor let the
air out and remove the tractor tire core housing.
with the valve stem at the top, attach the adapter
you got from Gemplers, and hook a hose to it. I
use a washing machine hose. Install the barrel
plugs in the barrel with the fittings on them.
Then lay the barrel down on its side with the plug
with the valve on the bottom. Barrel still on the
truck.hook the hose to the barrel, and open the
valve. If you put pressure to the barrel,no more
than MAXIMUM OF 10 POUNDS did I say MAX 10 pounds.
It took about 20 minutes to transfer the anti-
freeze into the tire. When it starts to squirt out
the adapter, its full, shut off the valve,
remove the hose and adapter and reinstall the
tractor tire core housing still leaking isn't it
you should have put the valve core back in the
housing while you were waiting for the tire to
fill. Don't ask how I know.Next step is to inflate
the tire to 12 lbs. Then do the other one.
Link
will tell you how much your tire holds. Good Luck
Oh, Don't get that $8.25 Adapter from Napa. Its
to slow Link
will>Link tell you how much your tire takes
LumbrJakMan
09-19-2006 14:13:12
I was surprised when I found out my 2003 New Holland came with " Peanut Oil" loaded in the tires. It will not freeze,rust, is as heavy as CACL and environmentally safe. Also if you are stuck in the woods and have to survive on fish from a stream you are all set to fry them . Seriously here in NH thats what the New Holland dealer uses.
JerryU
09-18-2006 04:05:37
Not too hard. In answer to your questions:
You can get the adapters at Gemplers.com. You need to pump the solution into the tires - a variety of stuff available. Standby is calcium cholride but this stuff will rust about anything it comes in contact with. Newer antifreeze solutions are available - check with your local tractor supply house. To pump it in get a small pump that is driven by a 3/8 hand drill and a couple of wash machine hoses. Hook it all up - put the valve stem at the top and pump away. Instructions come with the valve stem adapters as to how to vent the air.
If you are doing small lawn tractor tires, you can use windshield washer fluid.
Finally, before you go to all this -- get a price from your local implement dealer -- around here it is about as cheap to have it done than to do it yourself - if you have a way of handling the loaded tires -- they are heavy.
FWIW
JU
RJ-AZ
09-17-2006 21:08:04
They sell a garden hose adapter at most big tire stores, just follow the instructions.
old
09-17-2006 20:34:42
Here I go again. I offer this a couple times a year and a lot of people ask for it so. I have a page from a 1935 owners manual that tell a few ways of filling tires with fluid. One you can even do in your sleep if you want to. Drop me an e-mail and I'll send you a copy of the page. As far as what to use theres always the CACL but I stopped useing it because of the rust problem. I now use windshield wiper fluid in my tires. Theres also beet juice but I can't tell you any thing about that one
