Tool Talk Discussion Forum
Chemical license for weed killer?
Rod M1
09-16-2006 19:47:39
I�m wondering what is the cost and prosses of getting a chemical license for weed killer?
I�ve tried a few available from TSC and they start to grow back in a few weeks.
Tim B from MA
09-20-2006 10:29:21
 Re: Chemical license for weed killer? in reply to Rod M1, 09-16-2006 19:47:39
Glyphosate (Roundup) works great on woody / perennial plants. The trick is to use toward the end of the growing season (Sepember here in Mass.)when the plants are breaking down chlorophyll in the leaves and transporting it to the roots. Glyphosate hitches a ride and kills the entire plant.
Earlier in the season (before seed set) all the translocation in the plant is from roots to shoots. Applied then, the glyphosate kills the leaves and, maybe the stems, but does not reach the roots.
pbutler
09-18-2006 06:00:21
If you are using Glyphosate it will only kill current live weeds, new one can start growing next week.
I got a gallon of "Pramitol" from Rural King for around $33. Put in on good and strong and nothing will grow there for quite some time-like a year or two. I use it around buildings, fuel tanks, driveway, etc.
But be careful-if it runs off into yard or crops it will do the same.
CNKS
09-17-2006 14:15:22
In Kansas you don't need a license to apply non-restricted use pesticides on your own property. Things like Roundup, Banvel, and 2,4-D are not restricted use. Lasso, paraquat, atrazine are examples of a few that are. If you bought your herbicide at TSC, it was likely 2,4-D or glyphosate (Roundup). Normal rates of Roundup do not work well on broadleaf weeds, as it is more of a grass killer. 2,4-D does nothing to grasses, and often does not completely kill broadleafs, it just sets them back. Mix the two and you get a good kill, or better mix Banvel and glyphosate. There are many others, if you farm. If you are just a homeowner, the 2,4-D/Banvel/glyphosate combination, depending on what you have will usually work well. Always spray the weeds when they are small.
Rod M1
09-17-2006 11:47:36
"Is it actually the same weed putting back out or is it new ones germinating?"
It's weed putting back out. I mite be using the wrong stuff or to week.
paul
09-17-2006 19:23:23
 Re: Chemical license for weed killer? in reply to Rod M1, 09-17-2006 11:47:36
So - what are you trying to kill?
What are you using?
What time of year/ size of weed?
We _can_ help you.... ;)
--->Paul
banjo
09-16-2006 20:18:29
check with your dept. of agriculture. I have a private applicator license for Okla. cost about $30 and is an open book test.
OK-AL
09-17-2006 14:17:43
 Re: Chemical license for weed killer? in reply to banjo, 09-16-2006 20:18:29
License?
Do you have to have a license to spray 2-4-D on your own pasture in Oklahoma?
Inquiring minds want to know. . . :-)
OK-AL
banjo
09-17-2006 20:47:59
 Re: Chemical license for weed killer? in reply to OK-AL, 09-17-2006 14:17:43
No you don't need a license for non restricted pesticides. I got mine for Grazon P+D. Needed a better kill,blackberry vines.
paul
09-16-2006 20:18:27
Each state is different, slightly.
In general $50 and sit through a study afternoon & mail in a test & if you get a good enough score you are good for RUP chemicals for 3 years.
What weeds you trying to kill, & what did you use? I've had a RUP licence for 9+ years, never actually used a RUP herbicide tho.....
--->Paul
ldj
09-16-2006 19:55:28
